Question about Braun Syncro 7526 Electric Shaver
Braun 7526 shaver switch
The blue switch on the shaver that raises the trimmer and lets you select a moveable or locked cutter position if broke. The shaver would not shut off after I last used it. How can I fix this switch?
  • 1 more comment
  • Mike Hawkins Jul 04, 2012
    Use your cellphone to take a bunch of pictures as you take it apart. It can be tricky putting the little arm and rotating cam back in if you don't have pictures to guide you.
    When gluing the metal springy piece back down I used epoxy and a little spring clamp to make sure it was flat against the inside wall. It can't stick up even a little bit.
    If it binds in the future, I'm going to try pulling the blue button and spring off entirely. It may be trickier to keep turned off, or in trim mode but it may be useable.
  • Jerry Henefeld Jul 07, 2012
    I had already made the repair by eliminating the blue button prijor to receiving this solution. The switch moves fine but doesn't lock in position so If I travel I have to make sure to secure it in the off position.
  • Anonymous Mar 26, 2014
    Needs new motor
  • 3 Answers
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
  • David Jones Oct 18, 2010
    Thanks ,very helpful.
    Let me just add a vital bit of information
    On removing front assembly, to remove sliding switch and access spring clip under blue button you have to release locking clip (it's like a long sprung piece of plastic) from LH side by just pushing it to the right with a fine screwdriver etc. It's concealed under another piece of plastic.
    I also removed inward facig lug on shaver body (under slider) as this snags the metal spring when refixed
You can't turn it off because the clip became loose behind the blue button.
Let it run down the battery and then try and follow the steps here to fix it.
Posted on Jul 04, 2012
Will not turn off
GOOD LUCK!!
Was this helpful? Yes No 4 people thought this was helpful
Add a comment
    • davjones101
    • 1 minute ago
    Thanks ,very helpful. Let me just add a vital bit of information On removing front assembly, to remove sliding switch and access spring clip under blue button you have to release locking clip (it's like a long sprung piece of plastic) from LH side by just pushing it to the right with a fine screwdriver etc. It's concealed under another piece of plastic. I also removed inward facig lug on shaver body (under slider) as this snags the metal spring when refixed
    Reply
Oct 17, 2010 | Braun Syncro 7526 Electric Shaver
Sideburn cutter part needs to be put back on. It became loose and now has fallen out. I could fix this myself if I knew how to open shaver.
if the sideburn cutter has come off, it is because it is broken. You will need to replace it. You will find the item at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-activator-body-housing-with-trimmer-select-models-p-829.html
For instructional video on disassembling the shaver, also see shaveroutlet.com tutorial here:
http://shaveroutlet.com/video_tutorials
Oct 08, 2010 | Braun 8585 Electric Shaver
Braun 7680 won't shut off
Every time I have seen this problem, the switch apparatus was broken and had to be replaced. The switch/trimmer assembly comes with the case and can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
Apr 10, 2010 | Braun Health & Beauty
Hair trimmer does not work - no visible reason! Is this fixable or should I just get a eperate trimmer? If I need a new trimmer what is the best value one to get? Man Thanks Andy
If the trimmer is actually broken, you can not repair it. More likely, it is just jammed or has a buildup of hair particles and skin oils causing it to be locked up.
Take a very shallow dish of rubing alcohol and dip JUST THE TEETH of the trimmer in it. Then turn on the shaver and attempt to use the trimmer. Repeat this process several times. The alcohol may help remove any build up that is present. If it still will not work, you may have to help the blades out a bit by manually sliding the moveable blade back and forth once or twice. You can advance the moveable blade with the tip of a jewelers screwdriver or similar object. Once you've advanced the blade, do the bit with the alcohol again to be sure any remaining residue is rinsed away.
Feb 21, 2010 | Remington F720 Electric Shaver
Pop up cutter wont lock down and only one cutter works ,I dissasembled it and fount that on the cutterthat did not work that there were two hold down ears on that cutter were broke loose from the plastic...
Same thing happened to me. I took it apart and got it fixed but then could not get it to lock down (wouldnt go down the whole way) There is a plastic that locks it down (if that is broken your out of luck)--and springs that pop it up. The key to getting it back in place is to push it down very evenly straight so that both of the metal rods go directly into each of their respective holes.
Aug 15, 2009 | Remington MS280
Braun 7526 trimmer will not move to the up position
The trimmer is extended by the button on the opposite side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 24, 2009 | Braun Syncro 7526 Electric Shaver
Norelco 6735x trimmer head
Just pop up the top with the cutters. Next pull the cutters from the shaver in the back prongs. Insert the trimmer head and reverse operation when you are fiished. adrianjpater@usa.net
Feb 20, 2008 | Norelco Advantage 6705 X Electric Shaver
Braun Syncro 7680 Electric Razor
Great instructions.
I left out the plastic latch and the razor works fine. OK with me.
On step "f" there was a little guide on one side...I had to push that in before sliding the switch upwards...it slid right out after doing that.
Thanks...it helped a lot.
Jan 24, 2008 | Braun Syncro 7680 Electric Shaver
Problem shaving
People, never ever buy the Braun body cruzer!!!! It does not mather which version/type you buy, with 'all' versions the big trimmer fails to work after aprox, 18-24 months.
I have bought three version of them, the first one stopped working totally after about a year. With the second one the large trimmer blade did not work anymore, so I bought the newest cruzer version (shaver #3 by then) in the hope Braun would have solved this problem. But NO, the same thing happend. After 18 months the trimmer is broke and I can throw my shaver in the bin because you buy this thing for the trimmer.
Now about 3 years later I have in total bought 3 cruzer shavers from Braun and all are broke (i am also almost broke, those things are pretty expensive here). And of course Braun does not help, they just say you are beyond warranty or did not take good care of the product. But I did, I keeped it clean with the little brushes, I put oil on blades/parts, and when I had shaved in the shower I made dry.... so I wonder what Braun means with "taking good care for your product" but i think they mean something like: buy a new one and give us some more of your money.
I will NEVER buy a Braun product again! And be warned people, don't say you where not warned for this product when you buy one and is goes broke within a year.
Sep 16, 2006 | Braun Cruzer 3 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
1,909 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
