Wireless connection i have connected another computer upstairs with a belkin wireless usb there is a connection there but cannot access the internet. the main pc is working fine. been told its the encryption but where can i find this info for the netgeardg834g i have had it connected before but had to have pc wiped down and have forgotten what i put 1st time round .
  • 556 Answers
Here is the website to determine the precise model and get the manuals to assist in determining the configuration of the router.
http://kbserver.netgear.com/products/DG834G.asp
Posted on Dec 08, 2007
My belkin n USB adapter (f5d8053) has been unable to access the wireless internet at my new place, through the mwn-apr150n medialink wireless n broadband router. My other devices connect fine, it's...
Please check the Network Range B/G/N Signal.
This could be the issue if other aplications are able to connect.
Also try to delete Wifi Profiles using the USB and add fresh wifi networks
If not in install & reinstall the the USB Software on ur pc / laptop
Lastly if this doesnt work try to use the USB Adapter on another network / other device and try to connect
If it doesnt then u have a USB Issue
Cheers
Eddie
Jul 02, 2017 | Belkin Computers & Internet
System: Microsoft Windows XP, Prof v 2002, service pack 3 Dell computer: Intel(R) Pentium (R) M; Processor 1.60 GHZ; 988 MHZ, 2.00 GB Ram Cannot connect to internet using Belkin play wireless USB adapter...
1. You have to have access to a wireless router to be able to connect.You also have to be allowed to connect.
2. A wireless adapter will show all computers in the area wirelessy but if you don't have a key to access you will not be able to connect.
Jul 14, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
I have F5D7230-4 router. Modem downstairs connected to DSL. Computer upstairs needs a wireless card to work This is a ''G'' router, but it only picks up signal upstairs with a ''B'' card which I stole...
The Belkin F5D7230-4 router should offer "Wireless G" connections,
unless you have used its built-in web-interface to only allow "Wireless B" connections.
So, if your "upstairs" computer, with a "Wireless B" adapter, connects, it will connect only at the slower "Wireless B" speed.
If you want "Wireless G" speed, you will need to purchase a "Wireless G" adapter.
Nov 18, 2009 | Computers & Internet
Cant connect to internet with main computer, one upstairs is fine
The upstairs computer is wired or wireless ?
If the upstairs computer is working then the router must be working properly.
Check the connection between the downstairs computer and the router.
If it is a wireless computer then check the wireless connection status on that computer.
Click Here for step by step solution
Nov 05, 2009 | Belkin Computers & Internet
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
My belkin light is on but the internet connection to my laptop keeps breaking up consistently
This sounds like it is probably the networking cables as your PC is directly connected so shouldnt have problems with net access. Get new cables as a first step :0)
Jun 07, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin usb problems
if both computer's are connected to a router. Try disconnecting power cable from router for about 30 seconds then reconnecting. The reason that I suggest this is because you mentioned that there is no packet being trans/rec. You might also want to check the IP addresses to make sure there's no interference with the other computer's IP address
Dec 24, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
