Question about Lexicon Omega Pro Studio External Sound System
Omega --where to plug in???
I have an Omega, and want to plug my Casio PX555R keyboard into the Omega, but I'm not sure WHERE?? The keyboard has two 1/4 " 'line-out' (r & l) jacks---do I use two 1/4" cables? If so, Where do I plug them into on the Omega?
The manual mentions 'guitar', mic, & all three at once, but not 'just' a keyboard.
Sorry so inept...
3 Suggested Answers
SOURCE: Device is unrecognised always day per day
I've been struggling with this issue for about a week. My unit was locking up increasingly more often.
Two things I've noticed about my Lexicon interface:
1. Seems to be excessively hot.
2. The unit is not vented.
Yesterday, after reading a comment about the solder possibly being the problem, losing conductivity as the units warms up. I decided to run my Lexicon with the plastic case removed.
Since removing the the case, i have only had one instance where the sound stopped working, which i believe was a problem with Cubase in that instance.
I'm not sure if removing the case to keep the unit cooler is the solution. I may have improved a connection somewhere in the process of opening up the unit.
I can say that I went from getting a "new hardware found" message every two minutes to having virtually no problems since removing the case.
My next step will be to drill about 50 holes in the case to vent it before attempting to use the case again.
Best of luck to ya!!!
Posted on Jan 25, 2008
  • 1066 Answers
SOURCE: i cant hook up mic and guitar same time
get a 1/8" stereo to mono splitter from radio shack or the like. it should have 1 1/8"male end, and two female ends, you could possibly get a 1/8" male with 2 1/4" female connectors, or use an all 1/4 inch adapter, with a 14/ to 1/8 adapter on the male end.
this should divide the guitar and vocals into left and right channels.
Posted on Feb 27, 2009
Looking for a sustaining pedal for the Casio ctk 401 keyboard. What models will be compatible?
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Apr 22, 2016 | Casio Music
My casio px555r has eight consecutive notes which are twice as loud as all the other keys and not touch sensitive. It is the same for all the sounds. When I turn the sensitivity control to off, the...
Hi, There are two contacts for each key. one makes contact before the other, the time between the two determines the time the key takes to be depressed, hence the touch.
Usually the contacts need cleaning, but in this case as itis 8 notes it may be the common keyboard scanning matrix. The matrix is 8 x ..up to whatever so check the line/column connection, or the associated diode.
Usually this is an easy fix, just time consuming taking the instrument to bits.
Good Luck, Chris the Fader
Jun 03, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Casio keyboard won't power on
If batteries or power adapter does not power up the keyboard...possibilities are...if it has a fuse inside or fusible link check it.replace if blown.Another possibility is power component has a short. maybe from constant movement of power plug into keyboard.sometimes just by inserting the plug and wiggling it can solve the issue..having this fixed by a technician can cost a lot of money.but,if your keyboard`s value is less than the cost of fixing it,might as well replace your instrument.
Feb 21, 2012 | Casio 76 Key Smartmedia Keyboard
Need driver for keyboard omega sagitta OK 203
hi, everybody this is Jeff
I get my Omega usb keyboard that doesn't work with xp professional i need the software driver for it. thank you
Aug 24, 2010 | Lenovo Keyboard
PC does not detects my Omega keyboard anymore
First question I'd want to resolve is whether the keyboard is bad, or you have a system problem. Plug keyboard into another PC and see if it works.
If it does, try uninstalling the keyboard using device manager, rebooting, and plugging keyboard back in.
Mar 13, 2010 | Lenovo Keyboard
I have a casio keyboard and if i plug headphones into the audio hole they dont work it just plays out loud. help.
It is important that your headphones are STEREO tyoe as a monaural 1/4 inch plug will short out one side of the output audio.
Make sure the plug is fully seated as it has a switch in the unit that disconnects the speakers typically when headphones are plugged in.
If your speakers do not get cut off when you plug in the headphones, it is POSSIBLLE that the switches on the jack have been broken. This would require servicing.
Dec 28, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
As soon as I plug in/switch on my midi keyboard, the USB LED flashes
dear sir,
your problem is very simple. please check the didi key board seriel pin.some time the seriel pin is broken. your goole problem is network problem.please check the network connectivity. otherwise operating system problem.sometimes while your installing the operating system some files missing. so first check your computer network and serial port.
thanks & records
Aug 09, 2008 | Lexicon Omega Desktop Recording Studio...
Lexicon Omega Pro Studio External Sound System Logo
49 people viewed this question
Top Lexicon Computers & Internet Experts
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
