Question about Toshiba TP55F80/81 55" Rear Projection Television
Toshiba projection TV TP55F80
When I first turn on the set, it crackles and jiggles. Then as it warms up it will pop occasionally. The color is fine. Is this the tuner?
gbd1720@hotmail.com
    President:
  • 4,402 Answers
No flyback transformer
Posted on Dec 05, 2007
When I turn on my rear projection tv & the tv is cold the color will float,the picture will shake side ways for about 15 minutes.what can I do to fix the proble?
You did not provide a model so I am not sure of the type of set u have. Wheather it be CRT, LCD, DLP or LED. My 1st guess regarding "color float" is possably the convergence board/section of your set. And the warming up issue could be the result of cold solder connections and/or faulty caps on 1 or more circuit boards. Search your model number through the internet for clues.
Dec 08, 2012 | Toshiba Televison & Video
There was a slight squealing and then a loud pop and now no picture. We have sound but no picture. Toshiba 65" rear projection set.
Sound like the color wheel exploded. When this happens the tv will not let it turn on, now for the real bad news,,,, Toshiba does not supply just the color wheel, you will have to replace the entire light engine for around $450.00 to $650.00
Dec 18, 2009 | Toshiba 65HM167 65" Projection Television
When you turn the tv on it turns itself right back off
problem with the power supply board. check the regulator. voltage out. if you cant do it. visit you local service center
Jul 13, 2009 | Toshiba TP55F80/81 55" Rear Projection...
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Tp55f80 tv. to much red on screen
You have a convergence failure. It may be possible to simply re-solder the pin connections under the convergence output ICs as they have a tendency to develop cold solder joints which cause intermittent mis-convergence. If the solder connections are good, then replacment of the ICs will be necessary. Expect to pay $350-450 to have a toshiba servicer fix this.
michtech
Feb 17, 2009 | Toshiba TP55F80/81 55" Rear Projection...
TP55f80
the lenticlualr screen part number is 23837437. the part is no longer available.
Aug 06, 2007 | Toshiba TP55F80/81 55" Rear Projection...
Toshiba TP55F80 convergence problem?
check the convergence chips for bad solders or even the crt sockets, I would lean more on the ic's and surrounding area.
Apr 18, 2007 | Toshiba TP55F80/81 55" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
