Connecting 240 volt singer baseboard heater
I'm connecting a Singer 6' electric base board heater and can't remember how it was wired before i disassembled it to paint the metal cabinet.
There are two leads coming from the heating elements and two wires coming from what i believe is an internal thermostat. I'm using a wall mounted thermostat and want make sure I connect it right
  • Anonymous Dec 18, 2008
    do they sell singer parts anymore.
  • Anonymous Mar 13, 2014
    Electrical feed coming in from the left don t know how to use the junction box and the wireway to connect to the right.
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Posted on Feb 10, 2009
  • 625 Answers
Power from your panelbox goes to the wall mounted thermostat. From there a two wire goes to the heater. In the heater one overload wire goes to the heater. the other overload wire goes to one side of your LINE. the other wire goes to the heater wire.[LINE]
Posted on Nov 29, 2007
  • 4 Answers
For PROPER 120 volt wiring U have 2 colored Insulated wires(= guage of wire # /2: e.g. 12/2, 14/2 -bigger guage# = smaller thickness )+ an uninsulated ground -3 wires in all
1): BLACK-/Line-/POWER LEG-/ wire;
-which would attach to the 'gold' colored Contact point on a
Duplex Outlet)
2) WHITE/ Line/Neutral wire:
which would attach to the 'silver' colored Contact point on a
Duplex Outlet)
3) RAW COPPERwire/ GROUND wire;
which would attach to the GREEN colored Contact Point on
a Duplex Outlet)
In 240 VOLT WIRING their is a fourth that is a second
POWER LEG wire needed
4) RED (as in 12/3 wire- e.g.) Or WHITE (as in 12/2 wire) In so 240 VOLT wired DUPLEX outlet would have two gold contact points, one of the two of each slots on each plug would be horizontal, the WHITE wire of 12/2 romex would be used as the second POWER LEG--GROUND would be connected to correct Contact Point-GREEN-as in 120 volt oulet, THERE IS NO NEUTRAL in 3 wire - 240 Volt- wiring---
{check WEATHERHEAD-where wires come into house from pole- 2 black wires/ LEGS- intwined with silver support wire (the Ground) - needed for household 240 VOLT applications- Some Electric -major appliances-(e.g. Clothe Dryers)- use a NEUTRAL-
That should enable yourself with enough information to hurt yourself --Unless you make sure all POWER IS TURNED OFF to the wiring you are attempting to reconfigure for what ever reason.
Posted on Jan 21, 2008
SOURCE:
Can I connect 2 6 foot electric hydronic heaters together? I am replacing t electric baseboards that were installed attached to one another.
you have to be sure supply wire is able to handle total amp draw.it should be 10 gage.if it is,without getting too technical youre fine.
Dec 22, 2010 | Fahrenheat Electric Hydronic Baseboard...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Where do i connect load wires to 240 volt baseboard heater
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Oct 27, 2009 | Dayton Electric Heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
Do you have the installation instructions, they will tell you exactly where to attach your high voltage.
Oct 27, 2009 | Heating & Cooling
Replacing old with new
Are the heaters rated at the same voltage, if so just connect the white to one heater wires and the black to the other heater wire..Does the white wire have a tape around it. If it does that indicates that it is a 120 volt cuircuit and not a neutral, which means you have a 240 volt supply. Make sure your heater is 240 vac.
Sep 18, 2008 | Fahrenheat Electric Convector Baseboard...
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
2,452 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
