Amana top loading washine machine spin problems
What is most common cause(s) of timer not advancing to spin cycle?
  • skkashe Jan 04, 2008
    My washer filled up with water and would not operate. It was making a loud noice once in a while. The repair man thinks that it is the timer and is charging $250. I am afraid that it something more and it will be a money pit. Does any one have an suggestions?
  • 291 Answers
Bad Timmer motor
Posted on Nov 29, 2007
SOURCE:
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Spin cycle doesnt work
    Hi.
    Here a general troubleshooting for no spin problems : If you have no spin there may be different reasons behind the problem. Before advancing to
    With top loaders you need to add to the list problems related to motor and transmission. Such problems will be at the end of the troubleshooting list, right before inspecting the electronic control.
    With this model the more common failures are concerning drain system, lid switch and pressure switch.
    Here parts.
    Regards.
    Ginko.
    Jan 09, 2011 | Amana DLW330RA Top Load Washer
    TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
    HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
    May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
    Stuck in spin
    Hi!
    If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
    It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
    Do rate the solution as FixYa and revert for further clarification.
    Thanks
    Rylee
    Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer won't spin
    The first thing I would check is if your timer is advancing. Set it at th beginning of a wash cycle and let it go. See if the timer knob arrow advances. If it doesn't, your timer is bad.
    Oct 18, 2008 | Whirlpool LBR4121JQ Top Load Washer
    Ammana nav8805e
    If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
    Sep 02, 2008 | Amana NAV5800A Top Load Washer
    Washine Machine
    -Sounds like the timer is out. Check it out and replace it
    Good luck
    Mai
    May 16, 2017 | Kenmore 22642 Top Load Washer
    Washing Machines Logo
    113 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
