Question about HP Compaq nx7010 Notebook
Sd reader problem
I have a problem with the sd reader. It does not "hold" the mms memory card as it used to be. I had to keep the mms card pushed inside to be read. It worked for a while and now it can not read the mms card at all>
how can replace the sd reader and how can open it from bottom.
thank you
  • 1 more comment
  • ccccccccc Jan 07, 2008
    drivers for sd please...
  • Anonymous Jan 13, 2008
    I can not get my sc card reader to work either?
    HELP
  • Anonymous Jun 22, 2008
    sd is reading
Driver for the SD reader can be found on the nx7000 page by Compaq (but not on the nx7010!!)
Posted on Feb 01, 2008
  • 383 Answers
Found 2420 problems in 90 brands and 79 categories with 'memory card'
PC Desktops (33)
PC Laptops (47)
Posted on Nov 29, 2007
SOURCE:
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
How do i download pictures to my sd card
Try using an USB card reader. Insert the SD memory card into the USB card reader and then connect the card reader to the USB port on your computer. The computer will see the SD memory card as an external storage device, you can then copy the photos from the computer to the SD memory card.
Dec 03, 2011 | Computers & Internet
How to remove write-protection
Dear Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
May 14, 2010 | PNY 2GB microSD Memory Card
Got a new memory for my phone it is a nokia 6300 and the memory card is a 4gb sd micro card and it keeps saying card not formatted wot can i do to format it i have tried on the computer but it is still...
Most likely the phone that doesn't read it and the SD card reader can read "SD" cards but not the "SDHC" that a 4G card will be. All SD cards 4G and above are SDHC, and a plain SD card reader will not read this card.
Buy an SDHC reader, and get a smaller (up to 2G) card to use on the older phone that can't read the 4G one. Hope this helps.
Apr 07, 2010 | Nokia 6300 Cell Phone
We are wondering how to transfer photos from our d90 nikon camera to our computor
You need to use a memory card reader that is compatible with a SD card that is being used with your camera
Aug 21, 2009 | Nikon D90 Digital Camera with 18-105mm...
How to insert SD memory card into card rader in laptop computer
I would like to inform you that Acer's laptop doesn't support all kinds SD memory cards available in local market. Its not compatible with all physical dimensions of various memory card companies. So in that case you need to use EXTERNAL Memory card reader which is attachable to USB ports.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 29, 2009 | Computers & Internet
Trouble in formatting my SD micro sd for my lg chocolate cellpfon
use some other card reader for the purpose and format it from there.
Feb 14, 2009 | SanDisk 2GB microSD Memory Card
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
HP Compaq nx7010 Notebook Logo
300 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
