Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
I have a hitachi ultravision 60sx11ka
The tv is about 11 years old and now all of a sudden the bulbs will not light when the tv is turned on. I do have sound but no picture. I turned it off and on and finally it did come on. After shutting it off again it will not fire again. Any help would be appreciated.
  • sjrra Feb 10, 2009
    the picture shuts down abruptly, leaving intermitten audio. I turn it off for a while and it comes back on.
    Novelist:
    Champion:
  • 232 Answers
Cory, your losing the high voltage, could be bad solder joints in the horizontal circuit, ie; driver transformer, horizontal output transistor, or the transistor and associated capacitors have finally failed. If you keep trying and it will eventually start then it`s definitely bad solder and that`s a cheap fix from any local tech.
Posted on Nov 30, 2007
SOURCE:
Hitachi 55vg825 - sound fine / but no picture- only indicates No sync signal on tv-
It could be the lamp---if you remove the lamp look to see if it is shattered inside---average life on lamp is 2,000 hours or 2 years.
May 16, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Put new bulb in hitachi ultravision dlp tv and lamp light flashes and tv will not turn on. Have reinstalled old build and works fine. Is there any type of reset that needs to be set. New bulb no tv, old...
hey there it sounds like the problem is coming from your ballast board, the ballast board is the power source to the lamp. with time this part starts to wear out and get weak your old lamp is already burning out there for it does not need that much voltage to turn on but the new lamp has not been worn out or used there for it needs the ballast to be working at 100%
hope this solution helps
Sep 03, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50vs69a Rear projection TV. The t.v was on and suddenly the screen went black and the temprature and lamp red lights are flashing until i turn the t.v off. i tryed turning the t.v on and off but...
Check your door that holds the lamp assembly. It will turn of the power to the bulb if ajar at all, the switch responsible for this function may be fried aswell.
Feb 02, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
156 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
