Question about Canon Sure Shot 115u II Date 35mm Film Camera
Canon sure shot 115 u II Displays a flashing H in the display, and camera won't work
My son needs his camera to work for a photo class.  We replaced the battery and the display shows a flashing "H", and will not work.  HELP!
  • Anonymous Dec 22, 2007
    flashing "H" camera wont work
  • jackiemul Apr 05, 2008
    Having the same problem/ camera won't turn on/ only seeing the H
    Replaced the battery and put new film in the camera.
SOURCE:
Gryfox
  • 216 Answers
SOURCE: canon sure shot 90u
Take the battery out then push some buttons - the zoom buttons or the release button - til the LCD goes blank. This sometimes resets the circuit if there is really no problem. Then reinsert the battery and try again. If the H reappears, there is a problem with your zoom. It'll have to go to a repair shop.
Posted on Dec 01, 2006
daverh
  • 117 Answers
SOURCE: Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Posted on Jan 14, 2008
old marine
  • 2250 Answers
SOURCE: battery problems
Check the battery contacts inside the camera. Use a strong light, and if you see corrosion (black or greenish areas) on the contacts, rub them lightly with a pencil eraser until they are shiny.
Posted on Apr 16, 2008
old marine
  • 2250 Answers
SOURCE: How do you set the time on the Canon sure shot 80u
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Posted on Apr 17, 2008
  • 125 Answers
SOURCE: Canon Sure Shot 80 Tele/Date 35mm manual
try this website.
http://www.devicemanuals.com/guidedownload/Canon-Sure-Shot-80-Tele-User-Guide--TkRBME5qQT.html
I checked it out but looks like they don't have the manual but they can do support by email.
Posted on Jul 21, 2008
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
[email protected]
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
[email protected]
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
My Canon 5D mkI turns on ok, will focus, displays top and back, but it will not take a shot. I have two batteries, both which I have charged to full and tried (display shows full charge). I have also...
hicould you tell me the amount of shot number when you put memory card in? If yes, please move to manual position from auto on the side of lens. And try to press release button.there is other one thing you have to chack selftime release working or not. just let me know.
Jun 04, 2011 | Canon EOS-5D Digital Camera
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
Can't play back videos on my experna; memory card Sandisk class 4 8Gb. Have a canon Vixia HFR10 camcorder
Okay, ours is a different brand (JVC) but they may have some basic similarities in function. To playback video clips stored on the memory card, put the memory card in the card reader slot of the computer and put the files onto the computer. Playback the clips from your computer video or photo file. (Ours won't playback video stored on the memory card through the camera.)
To playback video clips stored on the camera hard drive through the camera, we open the viewer screen, look at the function keys on the camera body, select the "Play" button. On the screen it displays thumbnails of the various video clips. We use the toggle/function key to select from the menu containing options for playback, edit, delete, protect, etc.
May 16, 2011 | Canon Vixia HFR10 Silver Dual Flash Memory...
I shot 200 pics w/Canon EOS rebel XT 8mp camera on a new San Disk Ultra 4GB card. All pics look like flash did not work. It was working and I've shot hundreds of pics in same place, same lighting, using...
The CF card has nothing to do with the information that is sent to it. It is just a recordable medium that stores what the camera sends to it. There is some other problem with the settings of the camera that caused the photos to be underexposed. Do you use RAW mode for capture of the images? If you do then the Canon RAW conversion software can batch process the photos to correct the exposure.
Apr 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 06, 2010 | Canon PowerShot A85 Digital Camera
Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
Dec 19, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera not turning on
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
By the way, here's the info for India:
http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
http://www.canon-asia.com/index.jsp?fuseaction=contactus&prod_type=sales_service_in
Feb 03, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon Sure Shot 115u II Date 35mm Film Camera Logo
826 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
