Question about Sceptre X20g-Naga III 20.1" LCD Monitor
32" Sceptre LCD No POwer
32" SCEPTRE Will not power on . When tv is powered up you get red light showing it has power. The when you turn on via remote is supposed to turne power ligh to blue this does not happen.
Can you help
  • evilzucchini May 11, 2010
    I am having the seemingly common problem of my sceptre x20wg clicking and flashing the blue LED.
    I cannot, for the life of me, get into the stupid case tho. I have gone around the outside edge of the back of the case and unsnapped all the snaps. So I have that molding off.
    I found four snaps inside holding in the bracket for the screen itself. I unsnap those and can get the screen partially out, but it get stuck around the bottom near where the base connects.
    I figured the solution would be to remove the base. However, I can't get the base off of the back. I can get the foot of the base off, and inside the bottom there is a snap that I undid. But when I try to pry it apart, I feel like I reach a point where if I pry anymore I am bound to break it.
    So how do I get into it so I can see the board?
32 This is the same problem I am having with my Speptre X20WG Naga Monitor.
The power LEDS are usually red in standby and blue in opp; but now they just go purple and nothing happens..no sound no picture. I called tech support and no dice they just wanted my money, but I think all we might have to do is change a fuse on the main pcb! As you can see the white arrow isnt really pointing to anything specific! I think the fuse is the lt blue component, but am not sure. This is all I can offer! If you gat any good tips or if anyone else finds a fix please email me [email protected].
Thanks! and good luck m007!
Posted on Jan 13, 2008
  • Scott
    Scott Jan 13, 2008
    I also have heard that the remotes that come with the Sp TVS suck! So the IR lite might be weak try manuel opporation!
SOURCE:
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre tv, no sound no picture
In other-words it is dead. Check its main power regulator board. Replace it.
Jan 09, 2013 | Sceptre 32 X320BVHD 32 LCD TV
I purchased my Sceptre 32in tv in 2006. In the past 6-8 months I've noticed that the television has been taking extremely long to show the SCEPTRE screen after it has been turned on. Today I turned the...
The tv that take a long time to turn on.The cause is the tv power supply board,it not giving the tv the wright power voltages anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 27, 2010 | Sceptre X32BV-Naga 32 in. LCD TV
My Sceptre X32GV-Komodo got a problem recently: I heard a little sound like "PA" then the screen turned to black while I was using VGA to watch movie from a PC, the Power LED was still Blue. Later, I...
This type of issue is usually caused by blown capacitors on the power supply board. If you wan to do the repair yourself then go to our web site at: www.ccl-la.com/capacitors.htm and look at the pictures of what to look for in your monitor. Now open the unit and look for the power supply board, replace all parts hat look like the pictures and have even slightly bulging tops. The page on our wen site gives more information about the replacement parts. If you need to order parts we do stock them for same day shipping. If you don't want to do the repair yourself we do offer a repair service for your model for $45 plus return shipping. Let us know if you have any additional questions by email at [email protected]
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 17, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X32GV-Komodo keeps turning on and off
I replaced my own part and it works as new again .Go to ( Power-On.com )Look up part #LCD225-6M Power supply it only cost $65.00 and ups shipping was $10.46 2 day later I got it and 15 mim. later we were watching TV again
Mar 15, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
New Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Aug 28, 2006 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
922 people viewed this question
Top Sceptre Computers & Internet Experts
Ekse
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
