Zanussi fx1465W not working
When I start a wash cycle, the machine attempts to start but only runs for about 6 seconds, then it shows that it is washing, however nothing is happening. I do not hear water coming in. The machine has been working OK for the last 3+ years.
Any advice you can give me will be greatly appreciated.
  • 1 more comment
  • ianp01 Nov 29, 2007
    The water supply is fine; I have already checked this. I removed the hose at the washing machine end and turned the water on; no problem.
    It does make a humming noise for a few seconds, but then it just stops.
    As I said before the water supply is OK, but I don't hear water entering machine.
    The machine did start today after quite a long delay, so I don't know if this is the start of an intermittent problem or otherwise, however something is not quite right, and I would like to get to the bottom of the problem.
    Thanks for the input and prompt responses close.
    The door light still works as it should OK whether or not the fault is present, do you still reckon it could be the problem?
    Champion:
  • 249 Answers
The machine should make humming noise,before it takes in water check water feed to machine get back if you cant sort it
Posted on Nov 29, 2007
  • 1 more comment
  • eamonn close Nov 29, 2007
    IT SOUNDS LIKE A FAULTY P.C. BOARD OR DOOR INTERLOCK
    if Ihad to bet it would on the door interlock, easy to replace.bye for now
  • eamonn close Nov 30, 2007
    Intermittent faults are a nightmare, if it happens again try hitting the door where it locks, with PALM of your hand when door is closed,don't use large hammer yet! must go to bed see you. 1-20am here
SOURCE:
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
I have a zanussi washing machine mod fx1465w. I
If the drum is not turning this could be due to worn motor brushes,assumimg that its pumping out the filter will be clear and spin should follow @ program end.The motor brushes are secured by two screws each.....
Nov 24, 2009 | Washing Machines
Hi i have a zanussi fx1465w presently giving 5 bleeps &flashes of the indicator light any idear what this cauld be as the washer is not functioning after filling
5 flashes is motor down to earth usually resulting in replacing the motor. Sometimes the motor may have got damp you can try to dry it out if it looks damp this may work but its usually the motor itself.
Dec 20, 2008 | Washing Machines
Zanussi fj1254w washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 04, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
No movement, then loud beeping alert
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Oct 17, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
321 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
