Question about 3G Technology GL1821a (Black) 18 in. Flat Panel LCD Monitor
GEM GL 1821A black out
I have the GEM GL 1821A monitor. After a while, the monitor goes blank and does not respond when I shake the mouse. Initially I unplugged the monitor and plugged it back in and was able to get a response using this process for a while. Now I can not make it come back up no matter what I do. Do you have an idea what the problem is and how I can fix it. By the way, the monitor has a fixed cable to plug into the computer and also a fixed power cord to the transformer box. One more tidbit, the monitor acts similarly on various computers.
  • rogblair Nov 28, 2007
    I will try replacing power pack first. Will post again after repair.
  • 4,102 Answers
At first i would have said it was the video card in your comp,
but if you have tried it on other computers then that cant be the problem.
So if we no its deffinatey not the video card then it is going to be one of two things.
the first thing is its going to be the power pack over heating thid does happen from time to time and can be resolved by replacing the power adaptor this is the cheaper sollution as long as this is the problem,
The other problem it could be is a solder problem because if the monitor comes on everytime and then switches off the chances are if it is not the power pack then it is going to be a bad solder on one of the resistors this is also a common problem with monitors and television.
Now the problem you have got is do you replace the power pack hoping it is that over heating, but if you do this and it is not this that is to fault then you have wasted your money on a power pack that you dont need but hopefully can get a refund on.
Or do you look at the other option a bad solder this is also not very expensive to repair but without knowing what your looking for and without the equipment to check the resistance and finding where the bad solder is.
If you have tried a different power pack then the problem is going to be a bad solder now you can do this yourself but could take ages to find the fault yourself and buying equipment also expensive.
If you can buy a power transformer on the basis you can take it back if this is not the problem i would try this first but make sure you can get refund if it makes no difference.
If you have the equipment to do it yourself and you know aht you are looking for then this should be inexpensive just the price of some solder aslong as you have all equipment if you dont then take to repair shop tell them the problem and they should fix this for a small fee would be alot cheaper than replacing the monitor let me know what you want to do.
If you are capable of doing this yourslef you will need spec sheet but not having an idea what you are looking for will mean you wont find the problem and alot of people totally destroy the unit trying to repair themselves let me know
Posted on Nov 28, 2007
  • 1 more comment
  • paul proctor Nov 28, 2007
    check that the power pack has no damages in the leads when it switches off move the leads after it has switched off how long before it comes back on also how long till it switches off
    ok let me know how you get on it is either power pack over heating or the monitor itself.
    Also check all the air vents on the monitor are not blocked with dust try vacuming them to clear the dust.
    Also have you tried a different monitor on your comp as the video card could be on the way out also so try another monitor and see if you still have problem let me know how you get on ok
    does the monitor still work or does it totally stopped working now
I am looking for a power plug for my gem monitor #LCAO1F D3350382G
On eBay or Google Product Search or Amazon, search
GEM GL-822 power
or
GEM GL-822 12V 5A
There are a number available there. It is 12V DC, 5A
Apr 19, 2011 | 3G Technology GEM GL-822A/B 17" Flat Panel...
My GEM GL-1821A Computer monitor has a high pitch squeak that is intermittent in occurrence but sometimes continues for long periods of time. Got any ideas?
A high-pitch squeal is common in CRT TV sets and monitors. I've never run across this in an LCD monitor, but there's a first time for everything. If the sound isn't coming through built-in speakers (if this model has them) and is being caused by the computer, I would suspect the inverter circuitry. This provides power for the backlight, and there are transformers that may have become noisy. Because of their construction, it's possible for them to vibrate internally, and at a frequency that you hear as the high-pitched noise. There isn't a lot you can do to quiet them. When I worked on TV sets, I had mixed success using hot-melt glue to muffle the noise, but usually the only way to completely cure the problem was to replace the parts. It's unlikely you'll find the parts available for a monitor, so all I can suggest is to bear with the noise as long as the monitor is otherwise working properly. Or use this as an excuse to buy a new LCD monitor; they are quite reasonably priced these days.
Feb 16, 2011 | Think Computer GEM 15 Inch LCD BLACK...
Power Issues!
The AC adapter will go into shut down mode if the monitor is drawing too much current due to short circuits in the monitor, but it can also be bad caps in the power supply itself. You can try new adapter or check inside the monitor for shorted components.
http://s807.photobucket.com/home/budm/allalbums
Apr 24, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
I have a GEM 17" with power issues!
Sounds like your power supply capacitors are causing the power supply to shut down. Or you have a short in the monitor loading the power supply. You should try a different power supply.
Monitor Mike
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Systemax model GL-821A
it sound like a monitor issue, does it have lines, or turn white?
sorry to say all monitors do not last as long as the computer
Jun 05, 2008 | Systemax Scanport Gem GL-821A 17 in. Flat...
Scanport gem gl-19072
Suspected the main board / invertor.
Jan 21, 2008 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
GEM GL-821A has no display. The activity line does change from yellow to green. There is power to the display. What is wrong with it?
- lower resolution on computer ti 800 x 600 - look on screen to see faint image, if so, then inverter or backlight is gone.
Aug 24, 2007 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
Lcd GEM Gl-822A--dont show image
It sounds like a problem on the video / signal circuit board inside needs to have electronic troubleshooting.
Jan 21, 2007 | 3G Technology GEM GL-822A/B 17" Flat Panel...
3G Technology GL1821a (Black) 18 in. Flat Panel LCD Monitor Logo
145 people viewed this question
Top 3G Technology Computers & Internet Experts
William Miller
William Miller
Chris Larocque
Daniel Quinn
Daniel Quinn
Are you a 3G Technology Computer and Internet Expert? Answer questions, earn points and help others
