Question about Mintek DTV-373-D 37 in. LCD HDTV
Mintek dvd will not eject the dvd, it plays just fine.
    Genius:
  • 1,003 Answers
Unplug tv hold eject button down and plug tv back in still holding eject button turn on power
Posted on Jan 17, 2008
Dvd is stuck in player - won't play and won't eject
open cabinet of your dvd you will find out a lock open that pick up your disk during proseeing that is stucked
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
Same as others. DVD stuck..won't play, won't eject
I use a produce bag tie. Stick it in the bottom of the dvd slot after pushing the eject button and the disc pops out for me.
Jun 10, 2009 | Mintek LCD TV Progressive Scan DVD Player
Dvd will not eject when using eject button.
I am going to sandbag it. I can use that particular cd to workout with. I will just attach a dvd player separate since most postings can't use the dvd anyway after they get the cd out. Thanks for the help anyway! Susan
May 27, 2009 | Mintek LCD TV Progressive Scan DVD Player
Won't eject disc
I use a produce bag twist tie or a very thin pearing knife. After you push the eject button slide the twist tie in the bottom of the disc slot and the dvd should pop out.
May 10, 2009 | Mintek LCD TV Progressive Scan DVD Player
Unable to play dvd's on my mintek portable dvd player
I would get an optical laser lense cleaner ( it is basically a cd that has fine soft brushes on the underside to clean the laser lense )
something like :
laser lense cleaner link
Apr 13, 2009 | Mintek MDP-1720 Portable DVD Player
Mintek TV/DVD Combo
Hi have you tried using a dvd lense cleaner these are cheap to buy and will clean the laser lense this usually solves the problem but if not then the chances are your going to need to get the laser replaced.
Mar 26, 2008 | Mintek DTV-233 23 in. TV/DVD Combo
DVD keeps ejecting
I have the same problem.I can only get the recorded dvd's to play on the cheap dvd players like apex and such.
Mar 08, 2008 | Mintek DTV-323 32 in. LCD TV/DVD Combo
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
DVD does not play just spins and keeps showing loading.
Check to see if the disk is dirty, has fingerprints or is scratched. This has happened to me in the past and if dirty, cleaning it will correct the problem.
Jan 02, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Mintek lcd w/dvd player
see if the disk tray comes with a rubber belt. if it does then figure it out how to remove and replace it! if it comes with gears then it probably needs maintenance like greasing some part of it causing toomuch friction!.
replace the rubber belt if any! rubber belts often loosen especially with much heat build-up
Dec 06, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Mintek DTV-373-D 37 in. LCD HDTV Logo
85 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
