Home | Toshiba | COPIERS - E-STUDIO 650 Copier | Toshiba 3510c , err...
Toshiba COPIERS - E-STUDIO 650 Copier
Problem for Toshiba COPIERS - E-STUDIO 650 Copier
Toshiba 3510c , error code cd70
By petarpan130 on Aug 11, 2009
hi,toshiba 3510c can't started, saying service call and error cd70,
Solution #1
posted on Aug 11, 2009
Not Rated)
didi2005
Rank: Guru  Toshiba Expert
Rating: 86%, 116 votes
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Was this helpful?
Yes
No
Popular Solutions for Toshiba COPIERS - E-STUDIO 650
Questions and Unsolved Problems for Toshiba COPIERS - E-STUDIO 650
Do you recommend Toshiba COPIERS - E-STUDIO 650 Copier?
Answer
Answer
where can I find power supply for estudio650 toshiba , and how much?
Answer
i press start butten. scan begining & finish. but machin not starting & writing on... (More)
Answer
how do you put in the staples for SHARP copier ID# 54107166?
Answer
when i put the new toner she said me add toner, what can i do
Answer
We have a toshiba e-studio 550-810 printer driver gl-1020. It will only print the "odd... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba COPIERS - E-STUDIO 650...:
Top Copier Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
