Question about Brother MFC-8440 All-In-One Laser Printer
Fax, Copy, Scan Buttons do not change
The Fax, Copy, Scan buttons do not change. Printing does work.
The Fax Button is stuck on. How can I reset the machine to force these buttons to work?
  • Anonymous Mar 31, 2014
    powers on but won't copy
  • Brother Master
  • 1,113 Answers
Sounds like switch inside operations panel has broken, there is no reset that will fix it, will need new operations panel.
the reset code on this machine is menu # 2 8 6 4 then maintence shows enter 99, the first bit must be done super quick.
Posted on Nov 28, 2007
  • Soulvisitor
    Soulvisitor Nov 28, 2007
    Sorry should read menu * 2 8 6 4
SOURCE:
Fax and print buttons dont work konica minolta 7235
FAX is option do you have the FAX kit installed???, Scan is normally a kit also on that legacy Konica machine. if you have the IP address to the machine place it in your url box, if the machine is networked you should see the copier own web page
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 19, 2017 | Konica Minolta Office Equipment & Supplies
Samsung SCX-6345 machine is blocked by a fax arrived that captured both the printing and copying. how to reset the machine?
  • Turn on the printer.
  • 2 Press the "Machine Setup" button in the upper left corner of the control panel.
  • 3 Press the "Admin Setting" button on the touchscreen. Touch the password input area if the administrator set a password for the printer. Press the number keypad buttons to enter the password. Press the "OK" button on the touchscreen.
  • 4 Press the "General" tab shown on the screen.
  • 5 Press the "Default Settings" option. Press "Yes" to reset all at once the user settings configured on the printer, such as copy and scan options, fax settings and network and system options
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    May 19, 2011 | Samsung SCX-6345N Printer
    Will not switch to copy mode
    Make sure the Fax Mode button is not stuck in the printer. If not, unplug the power supply of the printer. The power supply is the black box behind the printer where the power cord is attached. Then, hold down Start and Cancel buttons at the same time while plugging back the power supply in the printer. Hold down the two buttons firmly while the printer is powering on until Language Selection appears on the LCD screen. Then, release the two buttons. Choose your preferred language. Set your printer like how you set it the first time. If this doesn't help, I strongly suggest you contact Lexmark Technical Support for further assistance.
    Jun 07, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
    This works!:
    noavatar_s.gif the_sunman
    Rank: Apprentice
    Rating: 94%, 4 votes
    I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!
    Sep 08, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
    Black page printwhen I try to copy or fax from my hp 6110 printer
    The printer isn't shot, but the scan assembly is, it sounds like either the scan lamp is dead or the sensors in the scan assy. You should also be getting a scanner error. I would try the reset, powering up with either the #3 or #6 buttons pushed, and see if a reset helps.
    Jun 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Default printer factory settings Lexmark X8350
    Please follow the steps given below:
    1. Press "Fax Mode" button.
    2. Press "Menu" button.
    3. Use the "Down Arrow" till the display reads "Maintenance."
    4. Press "Select."
    5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
    6. Press key pad "1."
    7. Press "Select."
    Please let us know the results.
    This will restore to factory default
    Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
    Change default ptr setting for lexmark x8350
    4. Press "Select."
    7. Press "Select."
    I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
    Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
    Phantom jams & button undetection
    Sounds like a button may be stuck or something. Reset machine by powering off, press and hold start button at same time while powering machine back up. Hold the start button down for a few seconds and release. This should help. Let me know if it does not and I may be able to walk you through another bit harder reset.
    Mar 12, 2009 | Brother IntelliFax-2820 Laser Fax
    Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
    Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
    Jan 28, 2008 | Brother MFC-8220 Fax
    Brother MFC-8440 All-In-One Laser Printer Logo
    181 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
    ctnozil
