Question about GPS
Goodmans sat nav gnav12
Unit turns on as normal mp3 player works,menu accessable but if navigation button pressed nothing happens.after pressing nav button mp3 ,menu etc will not respond until unit turned off and on again.have tried reset button but still the same.usb cable only for charging . will down load to sd card fix prob or should i bin unit.cheers
  • Anonymous Mar 22, 2014
    Have two of above units in three years neither will work to navigate. The reversing camera works ok. When I click on navigate it tells me to put in address, but I can not get past that window, it just clicks and nothing else happens. I have re set to default and reset, but to no avail. Can you he please help
Get your money back
Posted on Dec 25, 2007
SOURCE:
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 | Cell Phones
Tip
Saving contacts to SIM with Broken Screen Nokia 3109 3109c 2323 2323/c and...
Save Contacts to SIM blind. Nokia Broken Screen
Press Up once - Contact Menu
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
When i turn on my indash dvd keenwood player it jus says standby and nothing works
Press the SRC button to turn unit on. The SRC button allows you to navigate between input sources,i.e. tuner, cd, aux, etc. Press and hold SRC button for second to turn unit off ( it will display standby).
Oct 08, 2010 | Kenwood KDC-MP205 CD Player
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
This also maybe useful
Press left once
Press left once
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 | Cell Phones
Deleting pictures off of an insignia pilot mp3 player
You do it the same way that you delete music: Press your top right button to display the menu ("Settings", "recording", etc.). Roll your wheel to "Video"; press the navigational part of the scroll wheel to highlight the video that you want to delete. You'll then get options to "play", Add Now Playing, Play All, etc. At the bottom of those choices you will see the word, "delete". Scroll down to it and press the navigational button to highlight it. It will indicate a "No". and a "Yes". Scroll to "yes" and press the navigational button to delete it.
Mar 23, 2009 | Insignia Pilot MP3 Player
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
Dec 26, 2007 | SanDisk Sansa e140 MP3 Player
Mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Oct 31, 2007 | Kenwood Sirius KDC-MP522 CD Player
GPS Logo
272 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
