Question about Microsoft Xbox 360 Console
Processor / Motherboard Problem
I have taken my son's XBox360 apart and cleaned off the thermal past from the gpu/cpu and replaced with high end thermal paste. Now when it is powered up it flashs 2 rings and then automatically shuts OFF. What do I need to do,replace the motherboard possibly and if so where can I order one from?
THANx
Paul K.
My nephew had a similar problem, after you take off the heat sink you need to use a heat gun and apply it to specific parts of the mother board, then reapply the heat sink again and reassemble, here's a link to the description of repair, but the heat gun is cheaper. https://www.manncorp.com/expert_04.6x_xbox_repair_station/Xbox%20360%20Repair_071207a.pdf
good luck
Posted on Nov 29, 2007
SOURCE:
How to fix Red Ring of *****
You will need an x clamp kit to fix it. If you had taken all of the thermal paste off the cpu and gpu and tried to run it, you might have caused permanent damage that can not be fixed. You can try again. One of the reasons you get the ring of death is the solder joints under the cpu and gpu come apart from heat. The heat will melt the solder and the board will flex away from the chips.
Sep 17, 2015 | Microsoft Xbox 360 Console
Computer hangs after startup
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Dec 17, 2013 | EliteGroup K7VMM Motherboard
Cpu overheat
If the cpu is overheating the cooling fan may need to be changed, chances are the laptop will need to be taken apart and cleaned. A can of compressed air is ideal for blowing the dirt out of the heatsink and fan, also! removing the old thermal paste from the processor and heatsink and applying fresh compound will make all the difference.
Jul 02, 2012 | Computers & Internet
Compac cq50 110us has always run hot but now it overheats corre temp gadget reads temp at 205f then commences shut down vents are clear and a tech ie brother in law opened and cleaned system of all debris ...
I find that when completely cleaning a laptop, I will remove the Heatsink/Cooling Tube combo.
Allows me to thoroughly clean in-between the fins, and around the fins, of the Heatsink.
Also allows me to THOROUGHLY clean, the bottom of the cooling tube's metal plates, that sit on the top of the Processor, and GPU.
(GPU = Graphics Processing Unit. Slang? Graphics chipset )
Also the top of the Processor, and top of the GPU.
Then fresh, new Thermal Paste is Properly applied, and the Heatsink/Cooling Tube combo reinstalled.
Thermal Paste dries up over time. When it does it looses it's thermal conductivity properties.
Due to the cost, and ease of replacing, it is just cheap insurance.
There may not be Thermal Paste used. Computer manufacturers also use a Thermal Pad.
A material soaked with Thermal Paste.
CANNOT be reused. Once the metal plate/s of the Cooling Tube squeeze down on the thermal pad, there is an imprint made.
Trying to reinstall the Cooling Tube, will not squeeze the thermal pad down any further than it was originally.
The same amount of pressure is used. A gap will result. In-between the surface of the thermal pad, and the metal plate of the Cooling Tube.
{Thermal Pad's are J-U-N-K. They loose their conductivity properties pretty quickly}
1) You were having a cooling problem in the beginning, and this IS one definite area to address, along with cleaning.
2) You are right there with full access, when thoroughly cleaning a laptop.
Access to the cooling system.
A) Did your tech i.e. brother-in-law address this issue?
B) If so what thermal paste was used, and what was the method of applying?
(Method of applying?
Yes. It matters. Especially if a compound like Artic Silver, or similar to, was used)
C) Cooling fan is rotating? Good. Now, what RPM is it spinning at?
Spinning too slow will cause overheating problems also.
Are you sure the Cooling Fan is not spinning intermittently?
Spins okay for a while, then slows down, or stops, then spins again.
D) Let's look at the Cooling Assembly, for the Compaq Presario CQ50 series of Notebook PC's,
Top View, palm rest (Top Cover Assembly ) removed,
http://www.insidemylaptop.com/remove-motherboard-from-compaq-presario-cq50-cq60-cq70-laptop/
Scroll down to Step 17.
To the upper left of the photo you will see the black Fan Assembly. (Most of)
{ Fan is inside a surrounding cage, or shroud. You can see some of the Fan's blades. The Fan and the Shroud, are the Fan Assembly}
Just disassembling down to this point, in order to clean, is Not enough.
You cannot thoroughly access the entire Heatsink. The motherboard must be removed in order to perform this.
You also cannot clean, and replace Thermal Paste.
Observe Steps 18 and 19.
Shows the motherboard being removed, and removed.
Same direction. Top facing up.
Observe Step 20
This shows the Bottom side of the Fan Assembly, and also shows the rest of the cooling system.
Fan Assembly to the top right. Coming down the right side of the Fan Assembly, and curving under, is the copper Cooling Tube. (The Cooling tube is a slightly flattened copper tube, sealed on both ends. It is filled with Nitrogen )
Coming along the Cooling Tube area under the Fan Assembly, is an aluminum small rectangular plate. This metal plate sits on the GPU,
http://en.wikipedia.org/wiki/GPU
Going further to the left, is the metal plate that sits on top of the Processor.
You see the four mounting screws for this metal plate, circled in red.
Step 21 shows the cooling assembly removed.
{The Cooling Fan Assembly, and the Heatsink/Cooling Tube Assembly, are two different assembly's.
Referring to both as the Cooling Fan Assembly, as in the article, is erroneous }
3) Heat from the top of the Processor, and graphics chipset (GPU) is absorbed through the Thermal Paste, and into the individual metal plate sitting on top of it.
The plates transfer the heat to the copper Cooling Tube. The heat is then transferred to the Heatsink, at the end of the Cooling Tube.
Air from the Fan Assembly goes through the fins, (And around the fins), of the Heatsink, and helps to carry heat away.
4) Thermal Paste
The top of a Processor, the top of a GPU, and the bottom surface of the metal plates which sit on them, is not perfectly smooth.
A magnified view would detail, 'Hills, Pitholes, and Valleys'.
When the two surfaces are mated together (Metal plate to Processor, metal plate to GPU), air pockets are created.
Created in-between the two surfaces.
Air is an Insulator. Not a Conductor.
Thermal Paste is an Excellent conductor of heat, and fills those imperfections. (Air pockets)
Tip:
When I state Thoroughly clean, for the top of the Processor, top of the GPU, and bottom of their matching metal plates, I mean THOROUGHLY.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 05, 2011 | HP Compaq Presario CQ50-110US Laptop
Cpu over temperature error cpu temp : 39 to 101 mb temp : 30 to 100
First step would be to check all cooling fans are running correctly. Second blow out the dust and debris from inside the computer. If the cooling fans are not running correctly you will need to replace them. Thrid have you added any new hardware or have cables that would interfere with airflow? If so move things around so you have good air flow around the processor. Finally (before we get into the professional portion) you might try adding additional fans to the case, there are fans that will go in a drive bay to help improve air flow.
CAUTION!!!! The following steps should only be taken by a competent professional:
1. Check the heat sink, is there thermal paste leaking out around it (too much paste was used). You will need to remove the heat sink, clean up all thermal paste and then remount the heat sink with a small amount of thermal paste.
2. Remove the heat sink, is the thermal paste dried up? If so, inferior thermal paste was used. Clean up all the old thermal paste with alcohol, replace the heat sink with a small amount of good thermal paste.
Of course if you are running the computer in an 80 degree room, that will affect temperature too.
Hope this helps.
Jul 27, 2011 | ASUS P5LD2-VM Motherboard
The red light is on and game wont come on?
the red light is one of the major problem in xbox360
1 Go Online and get a good repair guide
2 Open the case and get access to the motherboard. This is actually the trickiest part of the process and needs a bit of patience. Just be careful not to lose any screws or damage the case.
Step 3: Remove the X-Clamps. These are the clamps that keep the heat sinks attached to the main CPU and GPU (graphics processor) chips. It needs to be removed from under the mainboard and care needs to be taken not to bend the clamp as you will be putting it back on.
Step 4: Use heat paste and fit risers. You need to use some CPU thermal paste to make the heatsinks more efficient - this will prevent the console from overheating again. Reattach the heat sinks using some polythene risers to give a better seal
Dec 12, 2010 | Microsoft Xbox 360 Console
I have a "p4 processor with 3.06ghz speed";i recently having problem of overheating and my temperature is rising to 100degree when CPU utilization is 100%.. .This all happened when i took out my heat-sink...
you should make sure that the heatsink and fan are clean and dust free, then you should clean all the thermal paste off with som alcohol(preferably 90% pure isopropyl alcohol)but 75 will work too make sure the top of the processor is clean also,then reapply the thermal paste.that should help,but if temps still run high then you should look for a better cooler.
Aug 27, 2010 | Intel Computers & Internet
Sister, Son and I all have the same model Sony Desk Top Computer. Model VGC RB57GY. Computers are overheating and showing overheating error and shutting down. Mine now is shutting down after even a...
May I ask what Temperature you are referring to, and where you are looking for the temperature at/in?
In BIOS?
Do you have external software that reads these temps?
Motherboard temperature?
CPU (Processor) temperature?
ATI Radeon X300 graphics card GPU temperature?
(Graphics Processing Unit)
CPU temp:
What Processor is installed, and what is the maximum thermal limit for it?
Intel Pentium D Model 820.
http://ark.intel.com/Product.aspx?id=27512
64.1 degrees Centigrade, or 147.38 degrees Fahrenheit.
Checked the thermal paste to see if it has dried up?
Even if it hasn't, cleaning the bottom of the Heatsink, and the top of the Processor's case, and applying fresh, new, thermal paste is the way to go.
After a certain amount of time, thermal paste loses it's thermal conductive properties.
If it is a thermal pad, remove it, fly it out the window. They're junk.
Use fresh new thermal paste instead.
(Be sure to observe Anti-Static Precautions)
Fans are all working fine.
According to whom?
The tech?
Not doubting your abilities for one second. DO doubt the many 'techs' who profess so.
Computer case open, observe the Processor Fan. Ensure that is is spinning at all times, and not intermittently.
Also ensure that the fan is spinning at the correct RPM's.
(Revolutions Per Minute)
Same with the computer case fan's, Front and Rear.
Computer clean inside?
1) Processor fan?
2) Heatsink?
3) The area of the motherboard you can see with the computer case open?
4) The area Behind the motherboard, that you Cannot readily see, without removing the motherboard?
5) The ATI Radeon X300 graphics card?
6) The Heatsink on the Northbridge chipset?
Check the cable connection of the Processor fan to the motherboard, and the computer case fans, IF, they (Case fans), have three wires, AND are connected to the motherboard.
One wire is for Power
One wire is for Ground
One wire is for a sensor that detects when the fan should speed up.
Processor fan spin freely? Computer case fans? Feel like they/it, may have a bad bearing?
Let's diagnose together, and see if we can solve this.
If all of the above reads like a foreign language to you, I will explain step by step, and guide you.
Aug 16, 2010 | Sony VAIO VGC-RB57GY PC Desktop
What kind of CPU coolers are compatible with HP Pavilion a1710n?
That's a hard question to answer, you need to fine out what CPU you have inside and then look up CPU coolers for that CPU style. Since your using a pre assembled machine you may have a specialized hole pattern making an aftermarket cooler hard to find. and use.
Jul 29, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Microsoft Xbox 360 Console Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
