Kenmore 24.5 cu. ft. Side-by-Side Refrigerator with PUR Ultimate II Water Filtration
Problem for Kenmore 24.5 cu. ft. Side-by-Side Refrigerator with PUR...
Nested Problem?
By msmith53 on Nov 28, 2007
When the family told me the water dispenser was not working on my Kenmore 24 side-by-side, I opened the freezer and found the back wall bulging inward. I removed it and found ice clumps on the coils. I disconnected the water line below the door and there was no water flow to that point. Is the water supply line frozen by the great clumps of ice? How do I insure the great clumps of ice do not return?
Thanks,
Marty
Best Solution
posted on Nov 28, 2007
Helpful)
Sea Breeze
Rank: Guru  Kenmore Refrigerators  Expert
Rating: 90%, 745 votes
Marty, sounds like the refrigerator is not going in defrost cycle.There could be several factors causing the ice buildup. Symptoms of this are higher freezer and cold food temps If you could look around the door panel for a model number, Example:106.48062890 I may be able to help you solve the problem.
Causes could be defrost timer, defrost element, element wiring connections, etc. Let me know , Thanks, Sea Breeze
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24.5 cu. ft.
Questions and Unsolved Problems for Kenmore 24.5 cu. ft.
Do you recommend Kenmore 24.5 cu. ft. Side-by-Side Refrigerator with PUR Ultimate II Water Filtration?
Answer
Answer
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice... (More)
Answer
kenmore side by side.the fridge is freezineg everything solid.turned setting to 2 and still freezing
Answer
kenmore coldspot side by side Freezer side works fine, refigerator stays faily warm
Answer
Kenmore 363.50242000 not cooling well enough. We just bought frig secound-hand and hauled home... (More)
Answer
Ice or water used to occasionally not shut off and had to use the lock button, but now neither will... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
in , CA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
