Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
My Hard Drive keeps freezing up
I've got an HP a1330n with a Samsung SP2504C hard drive that uses SATA cable using Windows XP. It works for about 4-8 minutes, then the hard drive makes a grinding noise and it completely locks up whether in Safe or Normal modes. I have to turn off and turn back on again every single time as Ctr+Alt+Del doesn't work. I've not had it connected online either. It's frustrating as I can barely get the help 'tools' to install before I'm rebooting!
I've done the following in both Safe and Normal modes: Ran spybot Ran hijack this Ran adaware Left off attempting to install and run Trend Micro's PC-cillin Swapping the red SATA cable on the motherboard slot Ran a surface scan on the hard drive Emptied the .tmp files, temp internet files, etc. Used an uninstaller and uninstalled all older files (kids programs, Yahoo tools, every single instance of NAV I could find as well as , AT&T Self Help Tool, etc.) I'm at a loss. There is a warning 'grind' just before it shuts down. I've searched many developer forums, but I'm not a programmer or a tekkie. Any advice? Also, there's no updated BIOS for this model; I've looked into that as well. Thanks so much for any help! Humbly, Lisa in Michigan
  • Eyden Nov 30, 2007
    Thanks for all feedback. Both fans are working. There is no updated BIOS according to the hp and Toshiba websites. Further, the hard drive isn't warm to the touch at all. I've checked all the cables and they are secure (even unplugging and re-plugging to be sure); however, the hard drive always boots up and xp loads with no problems after a hard boot. I actually got Trend Micro's scan to run 20 minutes last night before it locked up! :-) Further, when it does freeze, the mouse moves, but am unable to click or select anything. I only get the dreaded 'blue screen' once in a while.
    I've got the cover off and I can hear the grind coming from the hard drive itself, but it's unlike a noise I've heard before (not like the hard drive is searching, but a different noise [6 or so grind sounds only] and then it freezes up). I thought it was virus-related as it's been working fine for 2 years...
    I DON'T have the original install disks. It seems HP charges $30 for the restore disks and they don't come with the pc!! Thus, I was trying to fix it rather than replace as my father-in-law has things just so...however, if I have to, I'll replace.
    Anything else I can check? Oh, with regard to the SATA driver and/or controller, can I just remove and another will automatically load upon restart? I thought that worked with some drivers...Thanks again!!!
    Tallow, sorry I didn't answer your question. There is the normal hard drive noise (it's basically a very quiet machine) when the hard drive is busy, but the grinding noise is almost a click-hiccup (unlike any other sound it makes at any other time), it repeats 4-6 times and then freezes.
    Scholar:
  • 58 Answers
Well for this problem i have a few questions?
Do you really mean BIOS or driver. Try a different driver from HP or from the chipset maker for example silicon image.
Then.
If you don't have warranty buy a new hard drive. Cheap or expensive (cheap if you don't want to use it in a new computer if this is broken and you buy a new one). Just to exclude what is not good. With this hard drive you can install xp with the supplied restore cd's if you have. Then look if it again locks up. If not locks up it's your current hard drive. other than that it could be 2 cases. Something with the supplied sata driver of something with the sata controller. Also check the power connector maybe it's not attached in a good manner. Do not use 2 power cables on 1 hard drive. Like the molex (1 black 2 yellow 1 red) and the sata power. One of these and the normal sata cable. First try this and then you know more what to do
Posted on Nov 28, 2007
  • goovy75 Nov 28, 2007
    I don't think it's a fan because the hard drive makes a sound. If she is for sure the sound is coming from the hard drive.
    Problem Solver:
  • 36 Answers
Hi Lisa
You must be heading for the mad house by now. But if your not could you check to see if all your fans, I don't mean you singing fans but the fan on the PowerSupply, The Fan on the CPU., and the internal fan in the computer itself are working. It sounds very much like a heat problem. Is there any noise while the computer is running other than the grinding before it powers out.
Install 2nd Hard Drive with different connectors and different OS.
yes you can use either sata power or molex(4 pin) plug to power your new SATA hard drive but not both at the same time.
Mar 19, 2012 | Samsung SpinPoint SP8004H 80 GB Hard Drive
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
I have replaced the hard drive on my HP G5000 laptop with a Samsung HM161GI drive. All tests OK on BIOS diagnostics, but Windows XP Setup says no hard disk is installed??
This happens because the hard disk is natively a SATA and XP doesn't have a generic SATA driver so from its point of view the disk is not there. You will need to go into the BIOS and set the SATA connection to use the legacy/IDE mode.
May 16, 2011 | Samsung Spinpoint M7E HM161GI 160GB 5400...
My hard drive died in my HP pavilion 9795c. I replaced the hard drive, inserted the recovery cd and it says error loading operating system. I used a full version of xp pro with the same result. In setup...
I would suggest you pull the new hard drive out to make sure you've got the jumpers set correctly. Match them up with what you had on the old drive. Master / Slave / CS (cable select)
Once that's corrected you should be able to boot into the recovery cd so long as you set the boot options up correction in the bios.
Let me know if you get stuck.
Jan 22, 2011 | HP Pavilion 9795C PC Desktop
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Hello
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Good LUCK AND DO RATE THE SOLUTION IF HELPS
Dec 20, 2010 | Compaq Computers & Internet
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Problem replacing sata drive with eide drive in HP A1330n
if hard drive show in the bios setting and not loading the window then your hard drive not work properly.change your hard drive.
Jan 16, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
I try to install XP in my laptop but its say no
this might happen if your HP Hard Disk Drive is SATA ready, i think your using SATA HDD 3.0 version.. usually this design is partition with windows vista... here is a tip use a CD Diskwizard that reformat and repartition your hard disk so that you can install windows xp, trust me its works... Good luck!
Jul 09, 2009 | Computers & Internet
250GB harddisk only 130GB
try downloading any program that manages disks (partition magic for example ) and see if all the space appearsin that program, if so asign to that space a drive letter and format it .... (with the program that u will use )
Jan 16, 2008 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Computers & Internet Logo
1,476 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
