Question about Philips 50PF9630A 50 in. Plasma Television
Plasma tv how do I get my tv to play through my surround sound system?
The only way to do this if your tv doese not have a audio out is to run a HIFI VCR as the tuner through the amp and then from the amp to the tv this will give you the same result.
Posted on Dec 27, 2007
CONNECTING THE SET TO MY SURROUND SOUND SYSTEM.
What surround sound system can I buy to go with my panasonic viera th-50px80u plasma tv. One where I can here sound from cable and bluray
Jul 03, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Sound Issue
hi.On my surround system i can play dvd's and only get sound.The tv says not receiving signal.Any help appreciated.
Mar 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
Open Questions:
Philips 50PF9630A 50 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
