Question about Jabra BT125 Headset
Jabra BT125 Bluetooth
I can not connect it to my phone. I lost the handbook and also got a new phone. I tried pairing but it doesn't find the phone.
  • nysmokey Dec 22, 2007
    while trying to pair my jabra with my samsung m300 phone the headset starts blinking. the phone is still waiting to pair
  • Anonymous May 24, 2008
    Can not answer bluetooth
First u switch off the Jabra Headset..
then switch ON the Bluetooth in ur Cell.
then search for active devices in your cell..
while searching switch ON the bluetooth Headset.press and hold it continuous until the light is on.
you must hold it for approx 15 sec..
then the jabra wil be displayed in your cellphone....
tats it....add it....
enjoy,,
Posted on Dec 29, 2008
Http://www.jabra.com/Sites/Jabra/NA-US/pages/SupportProduct.aspx?productid=7e2df634-846f-4ce9-8350-0f0cb6df22e3
Posted on Dec 25, 2007
Cannot connect bluetooth headset with phone
read the directions from Samsung about pairing Bluetooth devices
Feb 19, 2010 | Jabra BT125 Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
Sep 10, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
I cant do pairing my jabra bluetooth head set to dopod
Turn on your BT125 by presiing button for 4-5 secs
in ur dopod go to settings>communication>blutooth
In the mode tab:check on > turn on bluetooth and >make device visible to others
Then go to devices tab: click on add new devices, your dopod will start searching nereby bluetooth devices...during this time press the button on your BT125 for about 2 secs, it will try to connect to dopod and a message will be displayed : "BT125 wants to connects......" say yes ...it will ask for the passkey enetr 0000 and there you go ...tada
Jun 26, 2009 | Jabra BT125 Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
I need to reprogram my Jabra BT125 to a new phone, but don't have the instuctions to do that.
7. Pair it with your phone
Before you use your Jabra BT125, you need to pair it with your mobile
phone. (Follow step 1-4 in fig. 3).
Jul 12, 2008 | Cell Phones
Jabra BT125 Headset Logo
258 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
