Question about HP OfficeJet t45 All-In-One InkJet Printer
Modem taken out by lightning
My fax modem was hit by lightning, everything else works fine. Where can I get a replacement fax modem for the T45?
  • Postal Dave Dec 01, 2007
    My company is unable to buy a new printer. My only hope is to fix the one I currently have. I wonder if the modem in the HP T45 is replacable?
    Problem Solver:
  • 36 Answers
Hi Dave
Are you aware that if modems or other components get shot with lighting that you vwery lightly to get intermittent problems on the machine thereafter. That product is probably insured on your house or business insurance. I would strongly recomment replacement and if you depend quite a lot on the fax get a seperate machine.
Sean
Posted on Nov 28, 2007
My laptop will not connect thru the ethernet cord to my modem, I think the network adapter got zapped during a storm but when I troubleshoot thru the laptop it says that the device is working properly -...
I went through several modems in a week due to a multitude of lightning hits. My modem always reported itself as fine, but it never worked. I would guess that your old machine doesn't use some feature which was destroyed. I would try to find a cheap adapter; they can be found for $10 or so.
-bin
Aug 25, 2011 | Dell lp-n21063-b Network Adapter
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
My 2003 server sees the modem v.92 fax, but i can not seem to use it. I tryed to reset it, powered off and back on, reinitialized it but nothing seems to work.
A lightning strike to the phone line can kill the line interface while the computer interface is still ok. This would produce the symptoms you describe. If you can open the modem, look around the phone line connector for burnt components or burning on the board.
This might also stop the phone line from working when the modem is connected, ie another phone on the same line will produce no dial tone with themodem connected.
If this is the case a new modem will be the cheapest way out of this.
Apr 20, 2010 | USR5686E, US ROBOTICS 56K V.92 EXTERNAL...
Fax Failed - Test Failed- Hardware Failure
had a lightning storm since? if so the modem in it may have been hit. i recommend pluging all devices into a electrical strip/surge strip to help prevent that. could be something else, but get back to us if you had no lightning around since it worked.
Aug 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
MODEM GETTING DISABLED AFTER WORKING FOR A DAY OR TWO
I would contact my ISP, the problem could be in the line somewhere. If there was a storm that went through lightning could of hit a phone line, or circuit, between you and the co.
Aug 10, 2009 | Multitech Systems Multi-Tech MultiMobile...
During a thunderstorm we heard a crack and believe our computer got hit - everything seems to be fine, except we cannot connect to the internet checked jacks and cords, but they are fine, could it be the...
If it's a broadband modem (cable or dsl) reboot the modem. Also look for diagnostic lights on the modem, they will give an indication if the modem is working properly. If after rebooting the modem, you are still getting trouble lights, contact the isp provider and explain your modem is no longer working. Most isp's replace faulty modems at no charge.
Jul 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Modem replacement inspiron 2200
Do you have access to another laptop that you could test the new modem in? Sounds to me like the new one maybe faulty :(
Try uninstalling the old one whilst its in via device manager then shut down and put new one in. If it doesnt detect it then its faulty.
Dec 28, 2007 | Dell Inspiron 2200 Notebook
U.S. Robotics (USR5633A) Modem
Dear sir,
I have purchase a U.S. Robotics 56K Fax Modem (USB) but when I installed in windows xp after modem driver installation some file could not setup properly then a message shown that continue anyway or cancel option. So that I need a fresh windows xp based U.S. Robotics 56K Fax Modem (USB) driver. My model no. is 5633. Please do something for us.
Thanking you,
Babu
Bangladesh Sericulture Research & Training Institute
Rajshahi-6207
Nov 21, 2007 | U.S. Robotics (USR5633A) Modem
Erase faxes in memory
I had the same problem and wanted to remove confidential faxes from memory in order to be able to sell or donate old T45. Manual does NOT help.
My solution is based on fact that I have a separate FAX and voice line. I connected my Windows machine (which has a fax/data modem) to my voice line and faxed a large (80 page) software manual to the fax machine. This fills the available memory, thus erasing the old documents. (To save paper, remove paper supply first, the fax machine will still receive and store the document.)
Nov 20, 2007 | HP OfficeJet t45 All-In-One InkJet Printer
HP OfficeJet t45 All-In-One InkJet Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
