Question about Victor 1430-3 Calculator
Set up casio calculator to show degrees
Change decimal to degrees
I am trying to change decimal to degrees on my casio fx 83es calculator and it gives me 0 degrees all the time, how should I set up the calculator
0 characters
1 Points
On my casio fx-82au plus calculator it won't
The capability of these calculators to handle irrational numbers in radical form is limited to square roots. Roots of index other than 2 are always displayed in their decimal representation.
If the calculator IO mode is set to MathIO, square roots will be displayed with the radical symbol. More complicated expressions with square roots might not be preserved and will be given as decimal numbers.
Oct 31, 2012 | Calculators
I have a casio fx-300ES calculator. It gives all answers as improper fractions. How do I make it give decimal answers?
Hi suebie50
Have a great day.
To change the output to decimal form, you can do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO).
The answer will show in decimal format.
You can also use this website whenever you have further questions in using you calculator:
Hope it helps.
Thank you for using fixya.
Sep 14, 2011 | Calculators
How do i change from getting answers in fractions to decimals on a casio fx-83ES?
Change the Input/Output Mode to LineIO. Press [SHIFT][MODE] and select [2:LineIO].
Aug 07, 2011 | Casio fx-300ES Calculator
I have a casio fx-83ES. I want the calculation to always give me decimals, it currently always gives me fractors, how do i change the setting so that I get decimals only ?
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Sep 27, 2010 | Calculators
Any way to make decimal answers the default? (casio fx-83ES)
you want a line output
Shift > Mode > 2:LineIO or on the graphics one its sometimes 10:LineO etc.
look for something with line in it
Steve :P
May 14, 2009 | Casio FX-115ES Scientific Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Tan cos etc with casio fx-83ES
set it up in correct rig mode, mode button (several times) until you get a window showing deg - rad - grad, choose deg (degree mode)
Nov 19, 2008 | Casio fx-300ES Calculator
Casio fx-83ES
there is a button SD close to AC button, standard - decimal try it .......or
shift+mode format math IO, change it to the other option
Jan 02, 2008 | Casio fx-300ES Calculator
How do I get decimal answers
I had the same problem. To change the output to decimals, do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO). This will cause answers to show in decimal format. I hope this helps.
I was able to find a manual at:
Nov 06, 2007 | Casio fx-300ES Calculator
Victor 1430-3 Calculator Logo
583 people viewed this question
Top Victor Calculators Experts
David Burbee
David Burbee
Are you a Victor Calculator Expert? Answer questions, earn points and help others
