Question about Whirlpool Duet GHW9150P Front Load Washer
Fixing an f 02 code
Our 3 year old duet has stopped working. the problem seems to be that it won't spin. when it is time for the agitation, all i hear is a slight buzzing sound. i then get an f 02 code. i unplugged it, made sure that all of the connections were tight, but it is full of water, so i don't want to drain it. any suggestions? thanks suzanne
  • raygunclan Nov 28, 2007
    well, i put a bunch of towels on the floor under the washer and drained it. i pulled out the little filter thing in the thing that unscrews at the bottom of the washer and there was all kinds of junk in there, including rocks, paper clips and a chopstick trainer! i cleaned it out, put it in, plugged the machine back in and, VOILA!!!!!
    hey! i fixed my own washing machine!!!! my dad is going to be SO proud!!!!!
  • lconnock Dec 03, 2008
    yes, my whirlpool duet does smell of mold/mildew. This is my 2nd Wduet (had one at the last house) and it was starting to develop this problem too. anyone have any suggestions?
Does yours smell of mold/mildew?
Posted on Nov 29, 2007
SOURCE:
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Bearing problem whirlpool duet h2
If you take the bottom kick plate off the machine you will find the tech sheet inside. This will tell you everything you need to know about you appliance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Whirlpool Washing Machines
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code OF 2 When this error code appears it happens during the spin cycle. I manually switch to the Drain/Spin cycle and change the spin speed to medium and press start. This fixes the problem each...
It sounds like you may have a motor control board issue. It acts like the motors brain and tells it what to do and when. part number 8182706. Also the closet error code i could find is a f/02 which means long drain, which could indicate a bad pump or draining cycle, alos knows as the spin cycle This should definetly be diagnosed by a technician. hope this helps
Thanks
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The time remaining on the wash cycle is blinking door is locked
M duet was also haveing problems and when it would stop in a cycle it would flash a leter and a # F 02 I hit cancel and restarted it the time was all messed up I looked up the code for F 02 and found this page, I will post the link below. it was a drainage problem I cleaned out a trap in the pump really easy to do and it just might fix your problem. Regardless ever Duet owner needs to know this and matain this trap I pulled out a bowl full of stuck in it. Good luck!
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Dec 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
change the spinner switch
Apr 01, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
141 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
