Question about Canon imageRUNNER C3200 Copier
Lifter in Paper Deck-P1 will not descends automatically and Open button on it blinks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
1-Bad sensor ( the one on the top side of the paper deck) or
2-Bad PCB
Posted on Nov 29, 2007
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Call for serviceU6:03
U6-03 refers to the large paper deck, tray 3 where the lift motor was unable to lift the paper to the pick up rollers. usually caused by a paper jam. Reset the machine by using #*C* then enter 15, press execute & then CA. If the machine displays the error again then the lifter motor would need to be replaced.
Dave.
Aug 18, 2014 | Sharp AR-M450U All-In-One Laser Printer
In tvs speed 40 printer all led light are blinking
follow these steps
1) Press ST1+READY button together
2)Turn on the tvs speed 40plus passbook printer
3) The 4 LED will blink 4 times. Release the button ST1+READY immediately after 4 blinks
4)PRESS ST1 - ST1+READY+EJECT starts blinking
5)again PRESS ST1 - ST1+EJECT+ST2 starts blinking
6)again PRESS ST1 - ST1+EJECT starts blinking
7)again PRESS ST1 - ST1+EJECT starts blinking
8)again PRESS ST1 - READY+EJECT starts blinking
9) printer is READY wait and PUT PAPER.
10) The paper goes in and comes out 3 times. will take about 2 minutes.
11) Paper ejects automatically after printing.
12) turn off the printer and turn it on.
Jan 24, 2014 | Office Equipment & Supplies
HP LJ 4200 does not lift the paper deck, but goes to ready state
If the paper does not lift, remove tray 2 and look inside to your right and you will see the paper lifter. Make sure the spring has not fallen off the lifter. You may need to replace the lifter. Also try lifting the paper deck by hand to make sure there is no obstructions in the tray itself.
Jul 30, 2013 | HP LaserJet 4200 Printer
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2011 | Brother HL 1240 Printer
Canon p1-dhv Lost manual and can't figure how to load paper roll!
http://www.usa.canon.com/app/pdf/calculator/P1-HDV_G_USA_HWB.pdf
This is for the P1-DHV-G but the paper loading process should be the same.
Feb 20, 2011 | Canon P1-DHV Calculator
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
Paper not being grabbed in the feed tray
The reason for this, I discovered, eventually, was because I had all 3 buttons at the front of the printer simultaneously lit up! When I turned off the bottom button (for automatic feed) the paper began immediately to to feed through as per normal!! So there we go. Problem solved. By an amateur.
Aug 26, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon imageRUNNER C3200 Copier Logo
61 people viewed this question
old marine
old marine
