Question about iLO 3200 32 in. LCD Television
Will not turn on
Was working fine then it made a little pop noise shut off and will not come back on
  • 2 more comments
  • zappa99 Nov 29, 2007
    cable went out, when it came back on tv screen was completely black, power light is on makes a slght pop noise but nothing happens. Lost the receipt, tried to take it bake by using the canceled check but wal-mart refused. Please Help!!
  • Anonymous Dec 01, 2007
    I HAVE HAD THE SAME PROBLEM AND THE SOLUTION DID WORK FOR AWHILE BUT NOW WANT COME ON AT ALL NO MATTER WHAT I DO. IS THEIR PLACE FOR REPAIRS?
  • nomorilo Dec 09, 2007
    We have the same problem, we turned our tv off one night and the next morning the power comes on but the screen is black with no audio. We tried to unplug if for an hour and then plug it back in but that did not work. please help.
  • ClarkJ Dec 10, 2007
    While watching TV it just poped off and will not come turn back on.
    Clark Smith
    [email protected]
Try taking the set apart and look for the fuse on the circuit board. Sometimes the fuse will pop when it blows. Other times it's the CRT...in which case...you're boned
Posted on Dec 31, 2007
We turned the tv off to go outside. Then when we came back in, our tv doen't want to come on. Green light comes on and then it goes back too red. It keeps doing that until u unplug it
Posted on Nov 30, 2007
SOURCE:
What would cause popping when I turn it off?
a shredding fan belt?
why not get the car checked out.??? buy a SHOP
you shut the engine off, and when you do, that it coasts to a stop
and did the noise come from the engine bay? and did the noise happen as engine was coasting to its natural stall or after that?
noises that happen, not moving are easy to find. so
get a competent mech, to find it. it be easy for them.
Oct 30, 2014 | Hyundai Motor 2004 Accent
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
My tv made a popping noise and then shut off wont
Power Supply Board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 19, 2010 | Televison & Video
Banging noise when motor turns off
Have you replaced your air filter recently? Often this is a symptom of a restricted return. The blower almost causes a vacuum in the duct work, and when the system shuts down the duct "pop" back out, causing this banging noise. Hope this helps
Feb 05, 2010 | Honeywell Electronic Programmable...
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Vizio GV47L not turning on after a pop noise
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Jan 05, 2009 | Sony KV-32S42 32" TV
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Sansui Amp
Bad supply capacitors...accordianman
Mar 09, 2008 | Audio Players & Recorders
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
iLO 3200 32 in. LCD Television Logo
60 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
