Question about JVC AV-32D305 32" TV
Av32d305 yaa retrace line on the top of the picture
Ihave a av32d305 w. retrace line i need to know which capacitor i need replace
Posted on Mar 31, 2008
Don't power
Posted on Mar 27, 2008
Yes on the top of the picture
Posted on Nov 29, 2007
Retarce line
Diagonal retrace lines at the top are usually the result of bad electrolytic capacitors in the vertical deflection circuit most vert. deflection circuits derive operating B+ from a horizontal flyback transformer winding rectified & filtered usually around 24 volts the electrolytic capacitor on this supply loses capacity or may totally go open causing the retrace lines,sometimes other electro. caps in the vert circuit can cause this too, depending on the age of the tv you may find multiple substandard electrolytic caps it's best to test all for capacity & esr. Without knowing more details about your tv brand,model and/or chassis i can't help further.
Apr 14, 2014 | Sansui Televison & Video
Blurred picture on screen, distorted sound with vertical retrace lines?
It sounds that either the screen voltage to the G2 grid of the picture tube, or the smoothing capacitor connected to the video output supply voltage has the fault. Replace the capacitor mentioned above. The value to this capacitor will be in between 10 to 22 MFD 350V or so.
Jan 15, 2013 | Televison & Video
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
What did you use to check the caps?
retrace can also be caused by the master screen being set too high.
Mar 23, 2012 | Televison & Video
3 vertical very thin lines on display how can i fix them
This is due to retrace and can due to higher screen voltage or a fault in the VERTICAL section.
Reducing the screen voltage will confirm this and if so there is a failure of a 10-20MFD/250 Volt capacitor.
If not a weak capacitor in the vertical section will show the retrace and replacement of the cacpacitor in this section must solve the issue.
Oct 01, 2011 | iiyama Vision Master Pro 514 22" CRT...
This fault is due to leakage of electrolytic capacitors in the vertical stage that is why top retrace lines are visible over the picture,if you are technical person check the capacitors in the vertical stage by replacing the same.
Jan 22, 2011 | Samsung Televison & Video
Several lines run across the top of the screen
Several lines acroos the screen at the top along with picture is a typical fault. You are seeing vertical retrace lines. Either the supply smoothing capacitor to the power supply given to vertical output Ic or vertical output capacitor connected to the vertical output pin of that Ic may faulty. Usually the supply smoothing capacitor seen faulty. It may be over 1500Mfd eletrolytic capacitor used there. It may get value reduced by 40 percent or so, this falult will occur. Please replace the two capacitors together and will get the result.
Oct 15, 2010 | Toshiba 27A34 27" TV
I have a panasonic tv with retrace lines at the topI
If you can locate the vertical IC you are nearby!. You will have to resoder the grounds on the vertical IC and any cap in the immediate area of this vertical IC is weak. I would replace them all as they will pull each other down. There may be four caps and the largest one, possibly a 25 volt 2200MF would be the only good cap. I dont have the specs on this set, but this will surely lead to a good repair!
May 06, 2010 | Panasonic CT-32D31 32" TV
Sir ihave philips tv 21PT94M tv will goes stand by & green retrace lines plese solve problem
pls check 180v dc from Eht or SMPS
[2]Video transister is sort or open if yes then replace
[3] Green cathode and filament is sorting in inside pictur tube.if yes then
1. filament voltage is less then normal
2. tube charging mathod to solve this problum.
Jan 22, 2010 | Philips Televison & Video
JVC AV-32D305 32" TV Logo
59 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
