Question about Radio Communications
Ford transit alternater
My ford transit alternater squels when i start my engine this is a L reg what is the problem and how do i solve it
Ether the belt is old and got hard or the belt is loose. Solution change fan belt or adjust to correct tension.
Posted on May 12, 2009
    Scholar:
  • 41 Answers
I am assuming your Transit is an older model. To get rid humming noises out of Car radios in the old days from generators and alternators there was a device they used to put on the alternator. I think it was like a capacitor. I am pretty sure you can still buy these at places like Jaycar and Dick Smith. They also used to put a device in the spark plug leads to stop interference from the motor/alternator. I don't know if this will help or not but is worth a try. Of course it could be a squealing fan belt and will do it until the belt warms up. That being the case a bit of soap or crayon on the belt will/should stop it. Hope I have helped.
Soleman13au
Posted on Dec 01, 2007
1988 ford ranger 2.3, why is my egr valve squeling it sounds like when ur belt squels?
Disconnect the vacuum line to it after the engine is running. It may generate a trouble code but if the noise stops you have a vacuum leak in the egr diaphram. You will need to replace the egr.
Mar 27, 2016 | Ford Cars & Trucks
Code for Radio on 05 Ford Transit Connect
hi harry can you see a number starting with m it should b on the side of the set next to the serial number get me that number and i can get you the code to unlock it for you send it to my email add a2wul@hotmail.com
Dec 08, 2013 | Ford Cars & Trucks
Fuse for the brake lights for a ford transit 260 y reg
I have a ford transit 2001 van and need to change the fuse as brake lights have gone but do not know what fuse it is in the fuse box. Can anyone help.
Apr 18, 2011 | Ford Transit Connect Cars & Trucks
Ford transit T reg 1999 does not start when engine cold battery good but will bump start . When starting engine turns slowly.
hi mate it sounds like a lazy starter moter but failing in that a one off problem is try changing your oil yeah it sound silly but a have had one in the past and that was the problem as the oil sank to the sump over nite and caused it like a dry friction once it was started and oil was up it would fire all day
Jan 26, 2010 | 2000 Ford Focus
Ford transit
the wires in the ignition plug, they burn, cut em out and use large terminals
Jun 25, 2009 | Code-Alarm Code Alarm Transponder
Lod chirping, squeling noise from engine in ford taurus. Belt is
The cam shaft stabilizer for the 2003 to 2005 have been a known issue. They will intermitantly squel till they go completly out.
I took my 2003 and 2005 Turas to a professional mechanic. They where able to verify the cam shaft stabilizer was the issue since the squeling noise was coming from top right side of the engine.
The surpintine (fan, AC) belts are locted on the left side of the engine.
Once I had the cam shaft stabilizer replaced. I never had that squel again.
Mar 28, 2009 | 2005 Ford Taurus
Transit not starting
The engine in this model doesnt need glow plugs, Its direct injection. If the van is not starting then it will be fir another reason. Ok, can you get a 17mm spanner and loosen the pipes onto the fuel injectors. Crank engine and see if there is fuel coming out. If not just crank it for a few minutes and see if some appears. If fuel appears, tighten pipes and crank for little while longer, see if it goes. If this doesnt work, i have a few more things to try.
TL
Jan 02, 2009 | Code-Alarm Code Alarm Transponder
Diagram of Location of a Starter Motor on Ford Transit 2002/2003
i have a 2001y reg transit tipper and i think the starter motor is going when i go to start it like grinds then some times it starts perfect
Nov 24, 2008 | Ford Festiva Cars & Trucks
Radio Communications Logo
269 people viewed this question
Top Radio Communications Experts
Marvin
Marvin
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
