Question about Yamaha DSP-A1000 5-Channel Amplifier
I have a yamaha rxv2500 no sound coming out
Amp on no sound with tv or tuner etc
  • 104 Answers
Check your speaker wire and speaker for open circuit.
Posted on Jan 21, 2008
    Novelist:
  • 236 Answers
No sound on all sources? can you check your tape monitor switch maybe on. if you're not using an eq with it connected to tape 2 then you wont have any audio. yamaha amp has tape2 function not in your selector switch, it's a separate button only
Posted on Mar 18, 2008
All input sources eg. DVD, cab/sat, cd, tuner etc have audio out of the amp ... but not the tv. Can someone help me with this one?
Have you checked to make sure the TV connection is from the correct TV output? The TV is not on mute? Recheck all connections. The amp obviously works ok.
Dec 26, 2013 | Yamaha RX-V1600 Receiver
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Hi I just bought 1080 blueray recorder and 6500 samsung tv.hooked up dmi cables to tv to denon amp and blueray to tv .had great picture and sound from denon amp.now can only get sound from tv.not sure...
Check your Denon amplifier with other input such as, input from ipod sound to amplifier or any source that provides sound to your amplifier. If you have a built in tuner in your amplifier, Does the sound comes out? If it does then check your dvd setting, e.g 5.1 channel surrounding etc. If there is no sound from amplifier, check your amp with qualified service tech.
Jan 17, 2011 | Samsung Televison & Video
My samsung is not showing Colour Picture, aand when watching RF channel there is no sound.
check tv tuner audio conections make sure your pc Audio Out connect in TV Tuner audio In. & TV tuner & speakers connect in TV Tuner Audio Out Jack.
Dec 14, 2010 | Samsung Computers & Internet
Hi would u please help me.. i am using your T.V tuner card SAA7130 product... after recording any progeamm v r not getting output audio sound.. we are adjusted in volume controller but also still we...
make sure none of the properties is muted in volume controller... Aux,line in,etc... none of them should be muted.... try recording.... still same problem...??? then try to connect the audio out & audio in together and record.... also check in the motherboard if any properties like aux, line in etc.. is muted, if so unmute and try recording again... any doubts...??? comment in the solution....so i can get an alert in my mail about your comment....
All the best.....
May 09, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Connected home cinema today and cant get sound when watching the tv
no sound out of tv?
sometimes that happens and you need to wire sound back to your tv from your amp. usually normal audio cables work.
or if you have no sound on your stereo from the tv.
you must have cables hooked up wrong or your amp is on the wrong selector eg. tuner,tape,dvd,cd. etc
Feb 21, 2010 | Panasonic Audio Players & Recorders
Tv not picture not sound
Is it varying the tuning voltage from 0v - 32v as it searches , if not then jungle/micro is faulty or check between tuner and micro/jungle
May 13, 2009 | Sharp 27C-240 27" TV
Cant figure how to hook my stereo up
what to remember is pre-amp is before the amplifier then the amplifier to the speakers, go this route, Tuner for radio? from the radio tuner out go to the pre-amp tuner input, then from the pre-amp OUT go to the AMPLIFIER IN, tuner, cd, dvd, tv, any source, if you are using a 2 channel amp and pre-amp this is relatively easy, a little more detailed for multi-channel pre-amps and amps but follow the same path, sound source signal ie. tuner to pre-amp, pre-amp out to amplifier and speaker hookup to amp channels,
Jan 29, 2009 | Audio Players & Recorders
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Samsung ht-thx 22 , no sound
You might want to try checking the connections into the receiver, and ensure that the cable system or antenna is connected directly into your receiver, and that you are using the tuner with the receiver, not the one on the TV.
Dec 28, 2007 | Audio Players & Recorders
Yamaha DSP-A1000 5-Channel Amplifier Logo
207 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
