Question about BenQ FP731 17" LCD Monitor
Benq fp737 17
I just bought 2 non working 17" lcd's for $10. I've challenged myself to fix them. I took them apart and one main board has a number of blown caps, the other looks fine. The one with blown caps would not power up, the other powers up but no picture whatsoever from vga, hadn't tested the dvi yet.
I took the video input board from the non powering one and put it in the powering one. I now can see the BENQ at startup very dimmly, but only with the dvi input. My first thought, the backlight. So I tried the screen from the other monitor in the now working chassis (LG PHILLIPS 170E01 A5 screens in both, btw). Same deal, saw the BENQ faintly but still all black.
I plan to replace the caps on the blown board and I may need a second input, although I will test the other one now that I know you can see the BENQ from the dvi input like that.
Do you think it's likely, given what I've described, that both backlights are out? or is it more likely that there's a power supply problem on my main board, if so, can anyone suggest how to test my backlights on their own and/or how to repair the board if that's the issue. I think I may start by replacing all the caps on both boards... thoughts?
Thanks,
Mike.
    Champion:
  • 220 Answers
How old are the monitors?
Normally backlights last at least 30,000hrs of working.
Normally problems on Inverter board transistors near yellow inverter transformers.
Samir
Posted on Feb 27, 2008
2 Suggested Answers
SOURCE:
viziks
  • 220 Answers
SOURCE: Benq FP737 LCD Display
This is how the original Design logic works.You cannot change it.
Samir
Posted on May 30, 2008
Hi, I have this Challenger 2HP pump out on the bench but can not separate the pump housing and impeller from the motor. I've removed the 3/8 bolt from the center of the impeller. And the band is off...
Take a look at this picture:
http://www.poolcenter.com/parts_pumps_pacfab_challenger_highflow.htm
Make sure you remove the mounting screws item 15 (2 ea) and item 9 (4 ea)
There are also 3 screws 120 deg apart item 12. Screw holes can be seen on item 2.
The impeller has a Locking screw item 10 that if it is not removed makes it impossible to remove the impeller.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | Pentair 2 hp Challenger Pump
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Jun 22, 2009 | LG 47LC7DF 47 in. LCD HDTV
Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
Nov 15, 2008 | BenQ DV3750 Television
White screen
dreaded capacitor issue. benq's were famous for it. if you are handy with disassembly and careful you can take it apart and do it yourself. look for any capacitors with rounded tops. i fixed one ... the part is only two dollars or so but it's a good feeling to know you fixed it instead of tossing it.
Robert
Aug 28, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq fp737s monitor failure
try resoldering the joints on c826 &c824 near the 4 yellow transformers in the power supply.
hope this helps
kevin numbnuts07
May 28, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Screen has power but is black
Looks like many faukty parts on the inverter board.. replacing will not be of much help as it will soon start get troublesome once again. I would suggest that replacing the LCD inverter board is a smarter solution. Hope this helps!
Good Luck!
Apr 15, 2008 | BenQ FP71G 17" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
My ben t705 moniteur.... problem
I DID REPAIR A MONITOR WITH THE SAME PROBLEM. IT TURNED OUT, THAT ONE OF THE TWO HIGH TENSION GENERATORS FOR THE 2 LIGHTTUBES WAS BURNED OUT. BY REPLACING THE POWER TRANSISTORS AND THE 3 AMP. FUSE ON THE MAINBOARD THE MONITOR IS RUNNING AGAIN VERY WELL.
Nov 22, 2007 | BenQ T705 17" LCD Monitor
BENQ FP731s Monitor Problem white blank screen
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
May 06, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
285 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
