Question about Panasonic KX-FL511 Plain Paper Laser Fax
Fax rollers when I try to fax a document, the rollers don't pull the original through enough to succesfully fax. Then it prints out an error log that it has a paper jam.
  • 4 more comments
  • Kenneth Johnson Nov 29, 2007
    The fax roller came out of the printer. Where do reinstall this part?
  • Anonymous Dec 04, 2007
    just won't pull paper through for fax or copy.
    Pulls about an inch, then stops, with ringish sound.
  • Anonymous Dec 18, 2007
    Had the same problem. Use alcohol ond the pick up roller and it works fine now.
  • willregal Jun 24, 2008
    Paper jams when I try to fax, copy single or multiple pages. I finally get it to go through if I get it in just the right spot sidways. Centering levers do not help. I cannot find the rollers to clean with alchohol, or how to get to them. willregal@comcast.net Thanks.
  • Anonymous Jul 02, 2008
    Yes, it picks up paper advances a short diostance stops and print out a document jammed. After trying several time it might go, but on the receiving end they get a blank sheet. Only happens on my 24/60# offset stock, never on my 20# stock. Problem all my letterheads and statements are printed on 60# paper
When I try to fax a document, the rollers don't pull the original through enough to successfully fax.
Where do I get the rollers and how do I install them?
us8181@YAHOO.COM
Posted on Apr 28, 2008
I tried the alcohol, swabbing the roller with a Q-tip, and it seemed to do the trick. Hint: Don't use the Q-tip on your ear first.
Posted on Apr 06, 2008
Had the same problem. Use alcohol on the roller and now it works great.
Posted on Dec 18, 2007
Alcohol worked fine. Fax is working. Just can't see my keyboard as clearly, now.
Posted on Dec 04, 2007
Run over with BMW.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Try cleaning the rollers with alcohol, they may be dirty and slipping when trying to grab the paper.
If it is too smooth, then they may need to be changed.
Posted on Nov 29, 2007
How do I place documents in fax Machine Face up Or face down
on my fax machine, hp brand, the item is placed in face down.
this should apply to other brands.
Oct 15, 2014 | Premium New Brother LC61 Series Combo Pack...
MyHP psc 1315 printer scanner keeps saying im empty but it is filled to capacity with paper. what can i do
Hi chrisneil,
This issue is generally caused by dirty rollers. Dust, paper scraps, and grime build-up on the paper feed rollers can cause paper jams. Follow these steps to clean the paper feed rollers.
Step one: Clean the rollers
Gather the following materials:
1. A clean, lint-free cloth, or any cloth that will not come apart or leave fibers Distilled, filtered, or bottled water (tap water might damage the product) Clean, lint-free cotton swabs.
2. Disconnect the power cord from the rear of the product.
3. Press the tab on the left side of the rear access door, and then pull the door outward to remove it.
4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
5. Press the cloth against the paper feed rollers, and then rotate them upward with your fingers. Apply a moderate amount of pressure to remove any dust or dirt build-up.
6. Locate the pick roller on the left side of the product below and behind the paper feed roller.
7. Lightly dampen a clean, lint-free cotton swab, and then use it to clean the pick roller.
8. Allow the rollers to dry for 10 or 15 minutes.
9. Check the rollers on the rear access door. Make sure that the rollers are not missing, that they turn easily, and that they are springy when you press them. If the rollers are damaged, replace the door.
10. Reattach the rear access door. Align the door pins with the slots on the right side of the rear of the product, and then push the door forward, snapping it into place.
11. Press the On/Resume button ( ) to turn on the product.
Step two: Print a self-test report
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product. If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.If the self-test report prints, but the original document does not , continue to the next solution in this document.If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
Hope it helps.
Thank you for using FixYa.
Aug 23, 2011 | HP PSC 1315 All-In-One InkJet Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
The left side of documents received do not print. How do I correct that?
I've checked my 3055 service manual and do not see this particular error as you've described it; I do have a couple of suggestions which may be helpful.
Since only half the page is printing, this implies an error with the print cartridge itself, it may either be low on toner or it may be damaged.
Does this error occur when you are printing documents from your computer or making copies as well? or does it only occur when you are receiving faxes? If the error is occuring regardless of what you are printing (or copying) and from received faxes I would have to conclude an issue with the toner cartridge itself.
You can visually inspect the cartridge by pulling back the plastic cover part and see if the roller shows signs of damage. If so, replace it.
Try shaking the catridge back and forth to even out the toner inside; If the cartidge is low on toner it's possible that what remains is only on one side.
Inside the printer, below where the cartridge sits is a black colored, somewhat spongy roller. This is called the transfer roller and if it's damaged it could be the cause of your print quality error.
Lastly, I would try a new HP cartridge, stay away from the generic brand ones as they tend to have a much higher failure rate and do not come with the HP warranty.
I hope this helps!
Sep 01, 2009 | HP LaserJet 3055 All-In-One Printer
Status Code 19
Look in you menus. Your log print out is probably set to on and set to print out way to frequently. You can turn that feature off.
You can go to Xerox.com, click on Support and drivers. In the search box type in 116 then go to support and then type in Log, There should be an answer there as to how to shut off log printing. You cold also type in code 19 when you get to the support page.
May 05, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Hp officejet 5610 All-in-One ADF automatice document feeder jams
where is it jamming. Clean the rollers with a toothbrush and water, horizontally.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Personal fax problem
its seems as though you may have a sensor problem or dirty rollers which feed in your original document. Try this:
open up the cover where you feed in your original document and clean all feed rollers which are normally rubber rollers and make sure you dry them off.
also check for a little arm sticking out which is a sensor flag and make sure it is not damaged and also that it springs back up when pressed.
Can you please let us know the make and model of fax please.
Hope this helps.
John
Jun 14, 2008 | Office Equipment & Supplies
Sharp F0-1460
"DOCUMENT JAM" refers to your original document that you are trying to send. Lift the top of the Automatic Document Feeder (ADF) and look for a tiny peice of torn paper. If not, look for a stuck sensor flag (might look like a small plastic finger). If still no go, clean the roller that feeds the original, it may be worn out and slick. Hope it helps Ed
Jul 13, 2007 | Pitney Bowes 9920 Plain Paper Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
159 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
