Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Top load washer does not stop filling and...
By patfedele on Aug 11, 2009
top load washer does not stop filling and over flows
Best Solution
posted on Aug 11, 2009
Very Helpful)
tstewart1956
Rank: Guru
Rating: 85%, 171 votes
TOP LOAD WASHERS HAVE A PRESSURE SWITCH UNDER THE TOP WITH A TUBE THAT GOES TO THE CONTROLS FOR THE WATER LEVEL
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
justaskjoe
Rank: Guru
Rating: 85%, 2063 votes
hello. If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
Indesit WIE 107 - taking water in and draining (nothing else happens) - display shows 'F-03'. Please... (More)
Answer
I have a Kenmore elite washer (model number110.27086601) and I just started to get a F1 error code,... (More)
Answer
whirlpool wtw6700tw washer had ld code and is not draining....did the motor must likely burn out... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
