Question about GE Spacemaker JVM1640SJ Microwave Oven
Removal of GE Spacemaker Microwave oven
How do I remove a GE Spacemaker Microwave oven?
  • 1 more comment
  • John Young
    John Young Dec 11, 2013
    is there a reset button or fuse in cae of overload, like a breaker
  • Anonymous Mar 31, 2014
    how to replace door latch on a ge microwave oven
    how do replace the door latch assembly
  • 4 Answers
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
2 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9173 Answers
SOURCE: removal of a GE spacemaker Microwave oven model
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded views and order parts and accessories here.
Posted on Jul 03, 2010
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Light in microwave constantly on
These can usually be repaired very reasonably. For removal help, see this YouTube clip.
Dec 08, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Installation / removal ge microwave / wall oven combo
Oct 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light that is inside the GE Spacemaker microwave?
with cord unplugged you can remove the main control panel and access to it
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Removal of a GE spacemaker Microwave oven model JVM48
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL Microwave Oven Model #JVM1460WA1- After removing the 3 bolts at the top, what are the next steps to remove the oven?
Jun 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Removal of unit from wall bracket
You can download GE installation instructions here.
Then you can see how it went up to help you get it down.
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removal
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,150 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
