Question about Samsung 710N V2 17" LCD Monitor
Birghtness 100 Popup
I have a popup on my Samsung 710N screen almost all the time. Is is a small box with BRIGHTNESS 100 on it. The box is white with a light blue inner band and black outer bank with an orange line showing it is 100.
I can't get rid of it. Sometimes it will blink off for a couple of seconds, then back it comes. Sometime it will stay in the middle of my screen. Any suggestions?
I browsed through the manuals and was unable to find which button is there to set it correctly.
  • 3 more comments
  • mithilesh Nov 29, 2007
    The brightness button is not stuck and still its doing the same thing
    Nothing that tech8 said made any technical send in point 2
    None of the solutions provided yet have been feasible
  • g3no Jan 29, 2008
    i have the same problem on my samsung 720N except that i can't even turn it off, and it isn't dissapearing. i believe it could be a flaw in the series, and it's hardly software-related as i have tried everything. =(
    New Friend:
Hello! i have syncmaster 933 having brightness 100 popup problem!
I found the best solution for it by tear down it and found a connector that connects these buttons and main board i just disconnected it making sure that the monitor is turned ON.
These buttons WONT WORK IF U DO SO BUT NO POPUP PROBLEM WILL BE IN FRONT OF YOU
Posted on May 13, 2012
Samsung was great.
Posted on Oct 13, 2008
Well i had the same problem, but i've done one tricky thing. I took a toothpick and thrustred it under the button with sun drawed on it. So this pop up disappeared. If i need to set brigtnes down itake toothpick out and then place it back, when brightness is 100%. after that i use down button to choose correct settings... :)
Posted on May 02, 2008
Put any other monitor on you pc and it will work. This is a monitor problem which Samsung should fix - not your computer, not Windows! Where is Samsung support?????
Posted on Dec 25, 2007
    Novelist:
    Champion:
  • 232 Answers
Don`t have the answer for the pop-up but heres customer services number for Samsung, if they can`t give you an answer I guess nobody can ): 1-800-726-7864
Posted on Nov 29, 2007
  • 4,102 Answers
Hi ya does the controll work whilst this message is on the screen.
Have you tried taking the batterys out of the controll switching the telly off at the wall wait 10 minutes and then switch it back on without the batterys in the controll doing this will let me know if the controll is the problem or the telly itself.
So give it a try take batt out switch telly off for 10 min leave batterys out of controll switch telly on and let me know what happens then ok speak soon
    Sergeant:
    Champion:
  • 298 Answers
1.If you have a manual see if you have any type of reset
to factory settings
2.Go into the picture menu set to default all settings
if this dont work...
its a glitch in the microprossor some data
line at a wrong level may have to dagnosed at
service center with Digital scope to catch the glitch
  • 1 more comment
  • Eugene Merritt Nov 29, 2007
    If that has helped you please press 'fixya'
    Your're saying your picture menu does not have
    an option to set all the settings color,tint.contrast,
    bright, etc like a preset where it changes all
    settings at the same time
    if this is the case set the brighness to zero
    all the off turn the set off for a few seconds
    turn it back on raise the brightness back up
    and see if the popup is still there
    I am assuming that brightness 100 refers to brilghtnss 100%
    or full all the way to the end if the brightness isnt at 100%
    this popup either refers to an error or a glitch in the signal level
    of a pin on the microprocessor that can be caught using a digital
    scope
    s your brightness all the way up
    the brightness should not be
    cranked all the way up because
    it can damage the HV system
    if you have to turn it all the way
    up there is something wrong
    with your set ii should be fine
    in the mid position if this is the
    case then turn it down and see
    what happens
  • 752 Answers
Sounds like your "brightness" button may be stuck. try pushing it and see if it feels the same as the other buttons (should feel it "click" a bit). Also see if any of the other buttons work, because if it IS stuck, they probably won't work...
  • Mitch
    Mitch Nov 29, 2007
    Are you able to access other video settings using the control buttons (like contrast, tint, etc..)?
SOURCE:
How do I disable/turn off popup box upper left of display
right click on the popup to get the settings
chose remove
please give a good details for a direct direction
Nov 10, 2014 | Computers & Internet
Allow popups in chrome
When you use Chrome and a popup comes up but it gets blocked.. You will see a small RED x in the upper right corner of your screen in the address bar. Click on the red X and you will see some options for that blocked popup. Choose "Always accept popups from that site". Reload the page and the popup should work fine after that.
Dec 31, 2013 | Computers & Internet
White spots on dlp screen
That white bar on the bottom? That looks like a "ghost" of an informational popup from your cable box or tv. In other words, just the background.
I'm a technician, so here's what I would try in order:
1. Is your cable legit and is the bill up to date? Some cable boxes will put up a message to tell you to pay up, or actually subscribe to the service. As described above, sometimes the cable box goobers up and doesn't display text of proper color for that popup.
2. unplug power from cable box, plug it back in. wait. check screen. Can you make the white box pop up by using a button on your remote? (what button?) While waiting for box to reboot, go thru the menus on your tv to make sure it's not your tv doing the same thing described above.
FWIW, I am a long-time cable technician. If you post the make and model of your cable box, (if you're still having problems) tv, and what actual service provider you use (Concast, DirTv, U-First, etc.), someone like me can help you better. Good luck!
Oct 19, 2012 | Televison & Video
The screen keeps going white
Possibly a problem with the backlight or Inverter, also reports of faulty motherboard to screen video cables
Have look here:
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=137278&modelname=NP-NC10&modelcode=&session_id=KpphnfK5hvXsn18gvx7d2Ymb2xt0pM4rMgTRnstpwGyPh9byDFpf!1920101254!17
If under warranty, I'd get this sent back
Dec 29, 2010 | Samsung NC10-14ROBL Notebook
D70s Flash lifts into position but no flash
Remove the 2 screws from the front of the popup flash The rear plastic cover will the clip off.
Inside you will find a small switch on the right side of the flash unit when it pops up the switch should make, if it doesn't try shorting it with a small insulated item the try the camera in low light and see if if flashes.
To fix you need to remove the spring-screw from the other side then gently prise the bracket off, then just pull out the small white sleeve on the right hand side of the popup near the switch, this sleeve moves in slightly and will not make the switch on the popup flash.
Gently put the flash bracket onto the camera, be very gentle as the wires are very thin. You will see the white plastic bearing has 2 small clips which need to be through the hole on the bracket the pin which activates the switch will then be in the correct position.
May 30, 2010 | Nikon D70s Digital Camera
Problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Sep 06, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Popup on monitor screen
first try unplug set from AC plug for about 10 seconds for full system reset.If not see if firmware (software) on set could be updated to newer version software...could be a software issue..
Nov 28, 2007 | Samsung 710N V2 17" LCD Monitor
i had the same problem.i called up the service senter of samsung and they were like, press the menu button and hold it for some time.immediately press the auto button.this would do auto lock.i mean auto adjustment lock.that solved the problem somewhat in my monitor.its not a permanent solution but it can help...
Jun 23, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Pop up box appears periodically
try bringing up the menu, and see if there's an option "factory default", and try that. you didn't mention what button on the remote you press to get rid of the popup, or what feature you are turning off to get rid of the popup,
Jun 28, 2006 | Samsung LTM1575W 15 in. LCD Television
Open Questions:
See all Samsung 710N V2 17" LCD Monitor Questions
Samsung 710N V2 17" LCD Monitor Logo
425 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
