Question about Microsoft Xbox 360 Console
I have looked everywhere
Ok...i think i have been reading this website four about two hours looking for my problem but have not found it. I bought my xbox 360 in Dec. of 06 and i have to say i have not had any problems until recently. Basically, i play it ALL the time, which from experience with the older xbox i know these things just wear out, but this is a stupid problem. When i turn it on it makes the most annoying and loud sound that sounds a lot like an industrial size fan. I have a intercooler on the back and that has always helped the system keep cool(i even tested the temperature to make sure) Anyway i turn it off and back on again and on the third time the sounds go back to normal. I was hoping this was a one time thing, but it has happened 3 days in a row now. Any suggestions?
  • 1 more comment
  • Anonymous Nov 29, 2007
    same
  • cashless92 Nov 29, 2007
    same problem but only with certain games
  • bchena1313 Dec 10, 2007
    Over the weekend i messed around with my 360 and figured out that one noise was my Intercooler...if i tapped the intercooler a few times i could get it to quite down, which was nice. I did buy a new cooler from Pelican...Pelican Xbox 360 Pro Cooler, which was really neat how it worked, but it doesn't keep the 360 as cool as the Intercooler. If you dont have one of those $20 intercoolers than i would get one. I have two 360s and one runs with it and the other doesn't and there is a significant difference in temperature. I think that overall my old 360 is on its last leg and it wont be long before it kicks the bucket. Over the weekend as well, my system scratched my Call Of Duty 4 disc, which really pissed me off, but i was able to get another one.
    President:
  • 4,402 Answers
Http://www.russellbeattie.com/notebook/1008759.html
Posted on Dec 08, 2007
Roger Black JX 286 - is the distance on this treadmill measured in miles per hour or kilometres per hour?
Firstly look Via Google, for your needs, Ive found some info on the Argos website.
Dec 12, 2015 | Exercise & Fitness
Radio went out in my 95 ford aspire
Read about the radio not working and you think you have a blown fuse . I had a blown fuse due to me blowing it by shorting out the dome light . After changing the fuse I had code 52 which is a low ground fault for air bags . I then looked to find the large four fuses under the hood and found that three were OK but when trying to remove the 80 amp fuse with a pliers it broke . when I got it home I pulled the battery completely out and found that the 80 amp fuse has plastic covers on both side that cover bolts that hold it in place . Removed the bolts to find that part was burnt of from the short . After replacing it all was good and hour of driving it reset on its own .
Jan 07, 2014 | 1995 Ford Aspire
Cooks essential electric pressure cooker lid
I found this website... look under Salton
http://missvickie.com/resources/parts.html
Oct 17, 2013 | Cook's Essentials CooksEssentials 4 qt....
Looking for 1997 holden vt calais engine
Look for Junk Yard , find there and swap engines .
Jan 22, 2013 | Cars & Trucks
Tunturi Rowing Machine R 202 the 4 wheels under the seat have perished and need replasing. Where can I puy replacement?
Ron C, I bought the parts you had listed from the Home Depot website of the 1-1/8" rollers and they did not work. The original rollers were 1-1/2" rollers or 38mm rollers with a 10mm center bore. I have looked everywhere I can think of for these rollers and they are nearly impossible to find.
Jul 03, 2011 | Exercise & Fitness
I bought a 2001 Sable and don't think the door keypad has ever been used. The seller does not have the factory setting. The manual says the factory-set code can be found on the computer, but I've looked...
The pcm is installed in the firewall on the right (pass. side). But the code may not be written on the computer it may be written in the computer.
Mar 02, 2011 | 2001 Mercury Sable
HTS22GBMARCC freezer works fine, fridge barely cool. I read many suggestions from folks on this and other websites that said the evaporator fan was probably bad. I measured the voltage on the connector...
ok your on the right track . the 12 volts that your found is only a part of the diag . think "" you have four wires ( why ) .. this is a engery eff?? model i belive and the compressor will run ad several speeds and so do the fans . so if fan is milti speed like the compressor in may not be going because the main control board is not telling it to .. look in the back and there is a cover over this board . remove it . now smell of the burn if your can smell it of if its clicking during the run it may be bad . now i would replace it because of what you said . and i think your problem s solved .. some time the sensor in freezer could cause this but its rare.. do the board first . mm ot a cheap part .. hope this helped ..
Aug 17, 2010 | GE Hotpoint Top-Freezer Refrigerator
Fridge not cold
HI thanks for your question. check to see if the fan motor is running in the freezer. that could be the problem. thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Frigidaire FRT18B4A Top Freezer...
Central locking. think I have blown control unit but carnt find it anywhere???
After a few more hours of digging, I finally had to painfully follow the main supply wire from the central locking fuse and found that the controller is in the drivers door. All that was required was to replace the copper track that I burned out on the circuit board. Probably it is quite common to have the controller in the drivers door with cars that don't have factory key-less entry! Otherwise I think it would normally be up high where it could get a good reception from the transmitter on the keyring, Like up high in the center of the dashboard
Sep 29, 2008 | 1999 Daewoo Lanos
RCA CRK76TE1 Programming codes needed for a Daewoo T.V.
the following websites has the codes for that remote
all you have to do is look for the right model
http://remotes.com/store/codes_original.html
May 26, 2008 | RCA RCR430S Remote Control
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
