Question about OKI C5200n Laser Printer
Service Call 177: Fatal Error on C5200 printer
If I turn the printer off then on again, it will sometimes work, but this error message keeps coming up. Is there something I can do to fix it, or do I really need to take it to a repair place? If so, do you have any recommendations for Southern California places to repair this printer? I live in the Pasadena area.
Thank you!
Claire
THANK YOU, Soulvisitor! I got an estimate for repair for over $200, and I was going to just go buy a cheap color printer (if such a thing exists).
Have a blessed Christmas!
Posted on Dec 20, 2007
  • OKI Master
  • 1,113 Answers
Replace fuser unit, just slides in, you can do it!
LINK to purchase Fuser as shown below
Service Call  177:  Fatal Error on C5200 printer - bdf7697.jpg.
SOURCE:
Error030 fatal error on oki c5200
Error030 indicates that an error has been detected in operation checks on the RAM in slot 1. First note the 24-digit addresses (generally 3), then restart the printer. Check reproducibility if possible. Repeat the same operation after restarting the printer and check if the same service call message appears.
May 25, 2011 | Office Equipment & Supplies
Fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Jun 23, 2009 | OKI C5200n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
All Lights Blinking Fast
You can try add that printer again.... from Printers and Faxes!!!!
Mar 25, 2009 | OKI C3400n Laser Printer
Have OKI c5200 Printer Message window reads Service Call 030: Fatal error Mac Mini OSX system What do I do? Prior to Message  Black Ink cartride was low and replaced cartridge after message appeared
I had the same error with an Oki C9600N. Called OKI, and was told one of two things has apparently gone bad: a DIMM (in slot 1) or the controller board. I removed the RAM, cleaned the contacts, blew out the slots (w/canned air), and reseated the RAM. Printer is back up and running. Hope this helps someone.
Feb 02, 2009 | Office Equipment & Supplies
Fatal error 002
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Take the printer off the network. (Remove the network cable) Then enter the menu and select network menu. You want to change the settings as described below:
Change the Hublink Setting to "100 base tx full"
Change the FTP Setting to "Disable"
Once done and machine says online, shut it off, reattach the network cable and restart the printer.
You may also want to change the printer's IP address.
If this does not help, or you cannot get past the 002 fatal error then the machine will require service.
Aug 08, 2008 | OKI C5200n Laser Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
C5200 printer
177 - Replace fuser
Dec 12, 2007 | OKI C5200n Laser Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | OKI C5150n Led Printer
OKI C5200n Laser Printer Logo
1,289 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
