Question about Canon MultiPASS MP360 All-In-One InkJet Printer
Mp 360 was printing ok now flashing error code 345
  • rfmaza Jan 07, 2008
    just replaced both ink cartriges and carage is makeing a loud clicking noise and error ##345 if flashing.
    Carrage wount move.
  • 3 Answers
How to repair Canon SmartBase MP360, flashing error code ##345
Short: Take apart and wash the ink clogged mechanical parts. Use hot water.
What to do (Long version):
First, use your head!
Dont rush, this operation takes several hours / days to complete!
-Mark all wires that look the same (especially white flat ones), take photographs when disassembling, or use photographic memory :P
-Take apart the whole printer, so there is only a metal frame left, with couple of paper-rollers, and motors, and the "Print-head cleaning" -system. Wash this cleaning-system.
In detail, remove at least following items:
-Main Power lead!
-Casing (Use brigh flaslight to see TWO front cover-screws under the dark plastic!)
-Scanner (BEWARE of fragile flat-wires)
-Main electronic controller board
-Some other shit, metal plate, plastic cover, you will see.
-Plastic base plate
-All materials that might absorb water. (two sponges, and one rubber foam part)
The two sponges are between metalframe and baseplate, they absorb exess ink. Wash these separately, and dry, or change for new. (I left the shorter one out, when assembling)
There is also one long rubber foam part that is near where paper comes out, (visible from outside the printer, when cover is opened).
To get rid of the excess ink: Wash dirty parts heavily for 10 to 15 minutes with hot water. When outcoming water is clear, then it is clean.
-I let it to dry for couple of days (on heated floor), but you can use your imagination, compressed air could help it dry faster.
Assemble it back together, and it works.... at least MINE did xD
Not exactly shure, WHY this helped, but i think it had something to do with a LOT of dryed ink in the "Print-head cleaning" -system. --> parts could not move freely. Or maybe some sensor was dirty? OR is this just a coincidense, and I happened to fix some other problem while taking the printer apart?
If you have no idea what youre doing, then don´t do it. But its broken anyway , what do you have to lose?
Have fun.
Posted on Jan 21, 2008
  • 1 more comment
  • Janiporo Jan 21, 2008
    Also, you can try the following. Preferrably, do both!
    How to reset waste ink counter on Canon SmartBase 360 (you SHOULD clean the printer too):
    1) Enter SERVICE MODE. (By pressing the black button with the star (in a head ?) above it, followed by scan, copy, scan
    2) Select TEST MODE (press right arrow button 13 times).
    Press -OK-
    3) Select [8] PRINTER TEST
    Press -OK-
    4) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
    Press -OK-
    5) Select 0. [INK COUNT].
    6) Press the ok key.
    7) It should return to showing the "8: Printer Test - 8-3 +"
    8) Press the [Stop/Reset]key - black key with triangle and circle on it - (returning to the state of 3)), and then press the [ON/OFF] key.
    Have fun.
    Also, after searching throught internet, this error ##345 occures when waste-ink-pump is jammed. Make sure it moves freely, after cleaning.
  • Janiporo Jan 22, 2008
    Updated instructions at -->
Mp 700 error code 345
please try this link...
Mar 10, 2010 | Office Equipment & Supplies
Alarm button flashes, check printer, press OK .Error 6A00 appears, Pixma MP 750
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 14, 2009 | Canon PIXMA MP750 All-In-One InkJet...
How do I change the Ink on ImageCLASS MP 360 Have been given printer and do not have instructions with it.
With the mp 360 you just have to lift the scanner unit with power on and the carriage will move to the center allowing you to install new inks. unless there is an error code...
Jun 24, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Flashing E3 error code for a paper jam
I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
Mar 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Smartbase MP390 Printer - error ##345
canon smartbase mp390 error ##345 check printer can anyone help me
Nov 01, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Jammed at far right (error message ##345)
I don't know if you have the same problem as me but my printer kept saying cartridge jammed so I opened it up and moved the cartride head gently to the left and got a flash light there is a little peice of metal on the base where the cartridges sit you have to make sure it is cliked back in and now mine works again.
I hoe this helps
Sep 20, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Aug 13, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
231 people viewed this question
old marine
old marine
