posted by byabrook on Nov 28, 2007
out of the blue, I tried to print a form from a webpage today and the print is stretched wide and doc did not fit on page. I checked the paper size settings, all was fine, defaults on all settings. All docs I try to print are now the same. I checked all settings. Turned off everything, reinstalled printer and drivers, even did a system restore.. problem still exists. I have another computer attached to the printer, and with that one printer working fine so I know the problem is my computer. Help!
Comment by byabrook, posted on Apr 12, 2008
xp, pcl, direct connection
Best Solution
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
XP, PCL, direct connection
Rating Locked! (?) byabrook has rated this solution as Inappropriate
Solution #2
Need to know what OS you are using - are you printing PCL or postscript. How are the computers connecting to the printer network or direct connection?
Comment by FrankR1974, posted on Apr 13, 2008
Great - just what I needed - Please check under Oki B4350 propertied - from the general tab go to "printing Preferences" then click on the tab "Job Options" and look at the scaling section in the lower right side of the window - if it is not set to 100% please reset it - let me know if this works
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for OKI B4350 Laser Printer
Email this problem
Email this problem
Can you Help with these Printers problems?
Repair Service
Find Printer Repairman Near You:
