Copying hard drive
I have a new WD drive I want to have as a back up. Using the Data life guard tools cd Files will not copy over to the new drive
  • copguy Dec 01, 2007
    I need to do a total copy of drive c to the new drive so I have a replacement backup, I did it before and now I forgot how to.
    Problem Solver:
  • 7 Answers
Copguy:
in windows xp (is that what we're talking about here?)
go to Start
Help
Search for Back up files
Back up files to tape topic
In the explanation there's a link to the Backup Wizard
Follow the instructions, when it asks to where to back up, just browse to my computer, to the WD drive and there you go, it should take care of itself. You can probably set it up to do this automatically through Events on the Control Panel.
Hope that helps.
Posted on Nov 28, 2007
SOURCE:
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
Im not able to copy any data to my WD 320 gb external hard disk. i formatted my entire hd n still the problem persists. so i tried writing zeros using WD's data life guard diagnostics tool, but it's...
Writing 0's to a drive isn't so much a diagnostic tool as it is a function to erase all data from the drive permanently. Unlike formatting which just removes the link to the files so you technically don't see the data, but it's still there. Writing 0's to a drive will take a significant amount of time, sometimes between 2-10 hours (depending on the software, the drive, and the size of the drive). I recommend doing an actual hard drive diagnostic, as hard drive lag can be attributed to a malfunctioning drive.
Mar 27, 2011 | Western Digital Passport 320GB External...
My hard drive stop data transfer for a few seconds and then strats it again - drives me crazy when listening to music from the drive
Copy one of the "music" files from the W.D. to your 'C:' drive.
Then, "play" that copy of it. If it stop/starts/stutters, it's your computer, not your W.D. device, that is the problem.
Otherwise, you have a problem with your W.D. device.
See: http://support.wdc.com/product/downloaddetail.asp?swid=119&wdc_lang=en
and "Download the Data Lifeguard Tools software (Acronis True Image WD Edition and user manual and the WD diagnostic tool)".
Run that WD Diagnostic Tool, to "test" your W.D. drive.
If it "fails" the test, then exercise the warranty to get W.D. to replace the drive.
If the warranty has expired, W.D. has a "Customer Loyalty" program;
buy a new W.D. drive through the W.D. web-site, at a discount.
Or, open the case, remove the disk-drive, and buy a replacement, compatible, disk-drive, and "transplant" it into your case, to revive your external storage device.
Dec 04, 2010 | Western Digital My Book Essential 1TB...
My WD wants to install syn software. None of the files look like the files originally pulled for backup. My hard drive crashed and I need to restore to a new Hard drive - what do I do?
When you connect the drive, ignore the sync option. Do note in your "my computer" WD will have two drive letters (one is a read only drive) that contains the sync software. The other drive letter will be where you data is stored. If you used the sync software to backup your files; you need to install to get your data back. If you simply copied your data from one drive to another; the files should be there in their original form.
Oct 18, 2010 | Western Digital WD Passport 250GB Portable...
I have been trying to install software for a WD Elelments
just copy all files from the cd into 1 folder, you don't need to copy it on external hard, you can copy it on local hdd. but you can if you want it. find the setup.exe file copyed from the cd and run it.
Dec 01, 2009 | Western Digital My Book Essential Edition...
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
Can't detect HD WD 500GB SataII 16MB cache
If you purchased a full retail hard drive the drive came with Data Life Guard tools. Boot to the Data Life Guard cd and follow the prompts to set up your new drive. This should by pass any bios limitations.
If your drive didn't come with the Tool cd you can download it from Western Digital's site.
Mar 23, 2009 | ECS 945P-A (V3.0) Motherboard
How do I copy a dvd or cd with Windows XP? Thanks!
Use this progam (imgburn) is free
-->http://www.imgburn.com
create an ISO file from the cd to your hard drive
them burn the ISO file to a dvd
Note: When burning start program will ask some options chosee to make it Bootable.
Jan 11, 2009 | Microsoft Windows XP Home Edition
Is there a way to recover lost data from my Western Digital My Book??
Yes, there is a way to recover lost data from a WD drive.
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Best regards!
Jan 06, 2008 | Western Digital My Book Essential Edition...
Recover SYNC Data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Oct 31, 2007 | Western Digital Passport WDXML800UE...
Open Questions:
Computers & Internet Logo
44 people viewed this question
Ekse
Alun Cox
