Question about Akai PT4799HD Rear Projection Television
Color tint of picture
Colors are not normal--too much red and green. Have tried to adjust on the menu and nothing helps. I looked thru a peep hole in back and all three bulbs are burning (I thought maybe one had burned out and that was the cause). Help
  • el carldo Feb 13, 2008
    colors are not lining up..red is really red and i have a green vertical line on the right side of the screen. I just replaced the deflection board. Please help!
  • Anonymous Feb 13, 2008
    red and green tint. have tried to adjust,but no good.have been on tv forumn and need to know part # of convergence board
Check out this forum,,.
sounds like a convergence ic board needing to be replaced.
i did a mute183, to do a self focus in the service mode, which corrected my problem, but lost the self focus function without going back into the service mode so enter at your own risk.
Posted on Jan 08, 2008
The figures on the screen have blue outline
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
CONVERGENCE SOLUTIONYou will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
Solution #2 - CRT FLUID FIX
Feb 01, 2013 | Hitachi 43UWX10B 43" Rear Projection...
My colors are not blending correctly anymore. My green is giving me a double picture. I have tried to blend them on the front and back but not luck. I need help
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2011 | Hitachi 50DX01B 50" Rear Projection...
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
Picture looks like you are looking through a peep hole
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 03, 2010 | RCA P52960 52" Rear Projection Television
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
It is like looking at 3d in all three colors. i
  • Screen looks 3D
May 30, 2010 | RCA D52W19 52" Rear Projection Television
Ther is a red line on the left side of the tv the blue an green is alright but it looks like it is in 3D i have tried to line the conrv- but still nothing the red is shifted 2 inchs to the right
  • Screen looks 3D
Jan 04, 2010 | Mitsubishi WS-48515 48" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Toshiba projection tv three colors
  • Screen looks 3D
Mar 23, 2009 | Toshiba 55H70 55" Rear Projection...
Akai PT4799HD Rear Projection Television Logo
243 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
