Question about Plantronics CS70 Wireless Headset
No 3 beep notification in the earpiece of an incoming call
When I first hooked up my CS70 headset the earpiece would give 3 beeps when a call was coming in. This is no longer working and I can't seem to find a fix for this in the users manual
  • Soprema Apr 08, 2008
    I have the same problem but in my case, it never worked. Strangly, after I received a call and only after the ring stop, I will hear the 3 beeps in my ear piece.
I had the same problem and the cause was the handset lifter and not the earpiece--if the ringtone is too low at the lifter, it won't be detected and transmitted to the earpiece. Cranked up the ringtone and everything is fine.
If that doesn't take care of the problem you might look at whether or not you're using custom ringtones which might cause a problem. Switch them back to the defaults and see if the problem goes away.
Posted on Dec 03, 2008
  • 32 Answers
One more thing you may want to check is whether or not the lifter sits right above the speaker for the ringing of the phone.  If it doesn't you need to install the mic attachment that comes with the lifter, and center it over the ring speaker.
Also keep in mind that the beep beep beep doesn't happen until the end of each ring cycle (i.e. phone goes riiiiiiiiiiiiiiiing then you hear beep beep beep during the silence until the phone rings again).
Posted on Apr 28, 2009
Use the included external mic to get it to Beep. A more interesting problem is to get it to stop Beeping. I can't get mine to stop while on speakerphone. Talking to support revealed there is no on/off switch. Turns out that the feature only works with the lifter. The lifter comes with the external mic but also has one included just on the bottom just under the actual lifter arm. If you're willing to void the warranty to stop the beeping permanently you can clip the wire to it, no more beeping! I have no idea why they haven't included an on/off switch for the bleeping beeping. I'm sure with a little ingenuity and radio shack you could make one.
Posted on Sep 04, 2009
Something interesting was happing with mine;
Whenever I cough, I hear the "bee-bee-bee" like I've got an incoming call.  Any loud noise near the phone will fire it off.  Not sure what the correlation is, though, since I would assume that those beep notifiers are being generated by the headset's base station detecting an incoming call.  But maybe not, maybe it's based on the sound of the phone ringing?  If that's the case, the suggsestion I offer would be to turn up the volume on your actual phone, and see if making it louder will fire off the bee-bee-bee.
Posted on Nov 12, 2008
Same problem here. Increasing ring volume cured it. Also, the coughing does cause a similar enough noise to make it bee-bee-bee. (Also, blowing down into a bottle of soda, like we did when we were kids, causes it to bee-bee-bee. LOL)
Posted on Feb 18, 2009
I've discovered there is a significant delay time from when the phone rings and the headset gives the beeps, although the time varies.
My theory to this is that since it is a wireless setup, as with all wireless systems, there may be intermittant interference which we can't detect between the base and the receiver.
I believe sometimes it takes a second or two or three for the earpiece to either wake up or hear the signal from the base or hear ringer noise through the microphone.
Regardless, I'm patient with it and I compensate. No accessory device on the market is perfect all the time; there's always the need for the user to adapt to how the device functions.
Posted on Jun 25, 2008
How do you hook up a ps3 to a plantronics cs70
Sorry Nancy but you can't connect a CS70 to a ps3. What Plantronics has available exclusively for Playstation 3 is the Gamecom P90. It's a bluetooth headset.
Good luck from Headsets Direct!
Dec 24, 2011 | Plantronics CS70 Wireless Headset
Hi, my Plantronics CS70 earpiece only stays connected for about 2 secs and then shuts off. The battery is fully charged and the earpiece is properly synced with the base. Any ideas? Thanks, Jeff
It sounds like it may have an incorrect setting for the phone. This is the 1-4 in the side of your base. The number that configures to your phone should be listed at the 3:00 o'clock position. Most phones are used on 1. Here is a link to the User's Guide, that may help. The only other thing is it sounds like the battery is not really charging, which means that it is a non-replaceable battery. In that case, you would have to buy a new headset.
Sep 08, 2011 | Plantronics CS70 Wireless Headset
The headset does not come on
CS70 headset does not come on:
If the CS70 base has lights, to show that it is getting electrical power, you may need to re-pair the headset to the base unit (the headset will usually just beep when you press the button). Here is the link for subscription or how to re-pair the headset and base.
http://www.headsetsdirect.com/plantronics-cs70n-subscription-pairing-instructions
If the headset doesn't beep or anything when the button is pressed, and the base has lights, it could be that the internal battery has worn out and the headset needs to be replaced. The CS70 is an older model that has been discontinued for a few years, however you can get the CS70N replacement headset which will work on your base.
http://www.headsetsdirect.com/72910-01-cs70n-headset.html
Aug 07, 2011 | Plantronics CS70 Wireless Headset
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
May 19, 2011 | Plantronics CS70 Wireless Headset
Need to know how to change the earpiece to a smaller piece for the inner ear
Plantronics has a very nice of ear tips for the CS70 that includes several sizes, so you can find one to fit your ear. Here is a link where you can purchase the set of ear tips:
Plantronics Replacement Ear Tips
Mar 28, 2011 | Plantronics CS70 Wireless Headset
The headset on my CS7ON is no longer holding a charge over 3 hours? Batteries are obviously needed. Where can they be purchased? Our headset was originally purchased with Grand and Toy.
Unfortunately, the battery in the headset is not replaceable, but you can buy just the replacement headset that works with the base. Here is a link where you can buy the replacement headset:
Plantronics CS70 Replacement Headset
Feb 08, 2011 | Plantronics CS70 Wireless Headset
How do I sync my replacement ear piece
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Dec 08, 2010 | Plantronics CS70 Wireless Headset
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
Oct 14, 2010 | Plantronics CS70 Wireless Headset
CS70N Wireless headset
The earpiece will make 3 short beeps when a call is incoming. Also the phone will still ring if you are within distince to hear the ringer. Hope this helps! SM
Sep 10, 2008 | Plantronics CS70 Wireless Headset
Plantronics CS70 Wireless Headset Logo
5,127 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
