Printer not receiving jobs
My office has a Kyocera FS 9520 DN KX. Our printer was working fine until a couple of weeks ago. Now the printer is not receiving jobs and there is no error message. The only error message is on the computer that sent the print jobs. My solution so far has been to turn off the printer for 10 seconds then turn it back on. Usually at this point the print jobs in cue start to print again. This happens with no frequency, sometimes the printer runs for hours without an error, sometimes it runs for 10 minutes until it stops. Any suggestions?
Mark
  • skykay Mar 23, 2008
    I have a MacBook/Leopard & when I try to print to my HP 2410, it works for 2-3 weeks & then I can not get it to print.  I call Tech Support thru Apple & they reroute my Airport Extreme & change passwords, & reinstall "Mac Os X Install Disc 1" which sometimes means being on the telephone for a couple of hours only to have it last a week or two & we have to go thru the same thing again.  They tell me that my HP 2410 must be going into the "sleep mode" & the printer will not print.  I don't know if going in & "waking up" the printer each time I want to print would solve the problem or not.  Do you have any suggestions??
    Thank You---Leon
I have a Mac Book/Leopard & when I try to print to my HP 2410, it works for 2-3 weeks & then I can not get it to print.  I call Tech Support thru Apple & they reroute my Airport Extreme & change passwords, & reinstall " Mac Os X Install Disc 1" which sometimes means being on the telephone for a couple of hours only to have it last a week or two & we have to go thru the same thing again.  They tell me that my HP 2410 must be going into the "sleep mode" & the printer will not print.  I don't know if going in & "waking up" the printer each time I want to print would solve the problem or not.  Do you have any suggestions??    Thank you---Leon
Posted on Mar 23, 2008
    Sniper:
  • 56 Answers
Hi Mark, first of all,You need to check ports on Your PC ,if this printer is networked.Second, try to set sleep or Energy saver mode on printer to highest possible time.To do that,just press "Menu" key on printer control panel and go through menu to find sleep mode.And maybe best solution is to upgrade firmware on your respectable machine.For that, You need :Compact Flash card type 1,Card reader,and firmware.Obtain or download firmware files or informations about that from Kyocera web site or from Kyocera service partner in Your country. Copy unzipped files to CF card(you need to format CF card on printer -Read user manual )Switch off printer.Push card in CF Card Slot in printer.switch on printer and wait till all light flashing on printer control panel.Switch off printer and remove CF card.You can contact me if you have any problems about that machine.BR
Posted on Nov 29, 2007
SOURCE:
Windows 7/64 doesn't list my printer
The cd only has the drivers that were available when the printer shipped. You download the latest one here:
https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1100._.EN.html#WIN7
And yes, it does have drivers for both 32 and 64 bit Windows 7
Apr 01, 2017 | Kyocera Mita FS 1000+N Laser Printer
I have a kyocera fs-c5016n brought it home from office. It was on a network there. I have it connected with a network cable at home to a router. Can't get it to change from parallel interface to...
The display just indicates the default interface. If you have everything connected properly and send a print job to the printer it will automatically switch and print out. The default interface can be changed but there is no need to for your application.
Nov 12, 2010 | Kyocera Mita FS-C5016N Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner bottle..press on the drum unit that sits above it..you will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Jan 12, 2010 | Kyocera FS-2000D Laser Printer
Kyocera Mita FS 1010 every few days it prints out all the pages
Format the harddrive, or go to the properties and change the setting that says leave copy on the harddrive, if all this not working try to initialize the memory and you will be fine.
double check on the driver properties check if it says direct printing or it keeps any copy on the machine.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 13, 2009 | Kyocera Mita FS 1010 Laser Printer
Printer
Check cable is secure from pc to printer
Check printer can print a status page via printer keypad and is online/ready
If these are ok then it is a print driver issue
Turn off printer, Unplug usb, delete and reinstall print driver
Jan 11, 2008 | Kyocera FS-C5030N Led Printer
1,658 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
