Question about iRiver H10 MP3 Player
Slider disaster Please help ! My H10 iRiver is a couple of years old and has been as good as gold until now: i have been downloading cd's quite happily but last night after I disconnected the H10 from the computer and tried to scroll through the different album options, the slider suddenly seemed to have a mind of it's own ! When you switch it on, it automatically scrolls down to the bottom of the screen even if you aren't touching the slider. When you try and select an album to listen to, you can't because it scrolls down to the album at the end of the list. It is impossible to listen to any tracks because if you select a song, the slider takes the volume down to zero, hence you can't hear anything ! I haven't dropped it or anything so am at a loss as to why this has suddenly happened. Can anybody offer me any ideas as to what is wrong please ?
  • CERB May 31, 2008
    Exact same problem for me. Although sometimes the slider gets stuck and pressing it doesn't move it at all.
  • Briony Alcraft May 31, 2008
    I have exactly the same problem. There doesn't seem to be a solution on the iriver website.
Did anyone have an answer?
Posted on Jun 02, 2008
I have exactly the same problem. Can somebody help?
Posted on May 31, 2008
SOURCE:
Hello.please give me a link to download the driver for Iriver h10 20gb because the xp cant recognize it .thank you
www.opendrivers.com/driver/.../iriver-h10-20gb-mp3-player-firmware-2.51-us-mtp-version-free-download.html
www.opendrivers.com/companydriver/.../iriver-free-driver-download.html
hi,this is few drive website address for yr Mp3,mayb can work for u :)
Jul 03, 2010 | iRiver H10 MP3 Player
H10 wants to lock up
sounds like a hard drive problem...
need to see if you can still access your hard drive through the UMS trick
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
If yes, try formatting the H10 hard drive, reload the latest iriver h10 firmware, and transfer your music files directly to the h10 music folder with Windows file manager.
Download and run Easyh10 free playlist maker, to build and save a playlist to your player.
also see this website:
users
Good luck.
Mar 20, 2009 | iRiver H10 MP3 Player
H10 6gb
iRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Aug 26, 2008 | iRiver H10 MP3 Player
IRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Aug 03, 2008 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
Windows media player vs. h10 20gb
Fimrware upgrade might actually result in this problem - check the iRiver help forums - i believe I saw a horde of people with this issue
Oct 27, 2007 | iRiver H10 MP3 Player
Iriver H10 saying system Files missing
Try doing a format via windows explorer. Right click on the drive and then format as fat32. Then unplug and open iriver plus. Reconnect. See if that works. Good luck!
Jun 29, 2007 | iRiver H10 MP3 Player
IRiver H10 20 GB
Hi Vera I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB >using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer easyh10-15.exe Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10 URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796 download 'easyh10-1.5_win32gui.zip' - connect USB cable between Pc and H10 - place H10 in 'Lock' position - use a tool ( refashioned paper clip ) to press the reset button - start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button while you press the 'On / Off ' button until screen displays USB connection, after emergency display - In Windows Explorer locate the ' removable drive' - Transfer your music files with tag information to 'Music' directory on H10 - Run EasyH10 - for Media database construction to display songs in MUSIC mode. - Playlist conversion, a necessary process for your playlist files to become compatible (recognizable) with an H10 player. - EasyH10 also imports/exports tuner presets from/to a text file. Prh
Mar 18, 2007 | iRiver H10 MP3 Player
Iriver h10 20 gb hangs quite often
it is not recommended to initialize while synchronising this will fry a couple of circuits inside
Feb 03, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
67 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
