Question about Foxconn P4M800P7MA-RS2 Motherboard
How to disable onboard VGA
I bought a new video card and want to disable the onboard vga. There isn't any option under the integrated peripherals menu for disabling the VGA, so I tried a couple of things I reduced the VGA memory share to disable, and changed "Init display First" to AGP, but none of them worked. I also tried to reboot the machine when the cable is connected to the external video card.
Moreover I disabled the onboard VGA on the device manager bu also it didn't worked.
I will be grateful if someone helps me to solve this problem.
Thank You very much
Ugur
  • trickyte Nov 29, 2007
    Thanks for the response. I bought a AGP vard :)
    I turned my bios settings to default and then changed "Init display First" PCI to AGP. I don't know how, but then my problem is solved :)
  • 205 Answers
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Posted on Nov 28, 2007
SOURCE:
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
EV3A GT520 video card installation makes my screen go blank. My gateway computer has an integrated chip for video, and does not even recognize the new card but its plugged in, fan working, etc.
some bios settings disables the add on video cards. to enable them go to bios setting by pressing DEL or F12 while power on your system. (u will see that a message appears "press ----- Key to enter bios settings). after entering bios setting u will see onboard VGA enable/disable. u have to disable onboard VGA in order to get the display thruogh VGA card.
Sep 21, 2011 | Nvidia GeForce GT 520 1 GB DDR3 Video Card...
How to disconnect in BIOC a built-in video card and to include PSI-EX?HELP!
Your motherboard's manual You can download it here > http://www.biostar-usa.com/app/en-us/mb/bios.php?S_ID=315
The procedure of disabling yout built in VGA card is :1 .Get into BIOS pressing DEL while booting or F2 (it usually writes it on a message upper left <Press xx for BIOS setup>.2 .From the main BIOS menu goto Integrated Peripherals > <Onboard GPU> and set it to Disable.3. From the Integrated Peripherals menu on the Selection <Init Display first> set it to PCI-Express.
Jul 26, 2011 | Biostar MCP6P-M2 Motherboard - v6.0,...
How do I disable my onboard graphics on my Acer Aspire T160? I want to add an HD 512MB pci express graphics card.
You can disable the onboard VGA card in BIOS, to do so
keep on tapping F2 button as soon as you hit the power button, under the CMOS search for VGA or onboard VGA and click Disable.
Thanks
Jitha
Dec 25, 2010 | Acer Aspire T160 PC Desktop
I am installing a Video-228pci-twin video card and need to disable the onboard video port. Jack H. [email protected]
The best way to disable the onboard VGA is in the bios settings. So find in bios settings the peripherals or the video section and disable the onboard video.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 06, 2010 | IBM NetVista M42 PC Desktop
Chaintech P35-121-16B9 need the manual or video jumper setting
Hi
Thank you for your query
Generally you dont need to disable the onboard VGA to AGP, all you need to do is to ensure that you plug the monitor lead into the AGP VGA card.
However if you wish to disable the onbaord VGA then please do the following
1) Ensure that the monitor lead is plugged into the onboard VGA card/port
2) Siwitch on PC then press F12, esc or del key to enter detup (When switching on there will be a message that says press X to enter setup)
3) This will present you with a blue BIOS screen, if yuo go through the menu there will be a option that says 'onboard/integrated peripherals'
4) choose that option and there will be a further option 'onboard VGA' this will be set to enabled. Set this to disabled and then save and exit
5) Note at this point you will have to move the VGA cable from the monitor from the back of the VGA prot to the AGP VGA card
I hope this has been helpful
Feb 28, 2010 | Computers & Internet
Need to disable onboard video to allow vga board to work.
You should be able to disable the onboard video in bios.
Boot up the computer, and you should be able to press {Del} and the computer should load the bios setup program. My Acer is currently out for repair, but I believe the main menu will say something like "integrated peripherals," and from the submenu you should be able to disable the onboard video.
Thank you for your question, and please let me know if there's anything else I can help with.
-Mike
Apr 05, 2009 | Acer Aspire™ T180 PC Desktop
How to disable onboard video on DC7600?
hello, sometimes if you disable on board VGA on your baord, the vga card will still not work well but i will tell you how to disable ooboard vga on your sytem anyway( got to the bios settings on your computer, select pheripheral setup and disable onboard vga.)
Dec 17, 2008 | HP Compaq dc7600 PC Desktop
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
How do I disable vga on ga-8vm800m?
During boot press DEL to get into standard BIOS settings, while in standard BIOS hold CTL key and press F1 this will alow hidden features to show in BIOS. Enter into Integrated Peripherals and you should now see a entry called INIT DISPLAY FIRST and you should be able to select between PCI Onboard and AGP (Depending on what you have installed). I have the same motherboard and had also upgraded to the 6200 which works great after finding the hidden BIOS features.
Hope this does the trick for you!
Jan 29, 2008 | Gigabyte GA-8VM800M Motherboard
Foxconn P4M800P7MA-RS2 Motherboard Logo
1,667 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
WTF Chuck.....
WTF Chuck.....
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
