Question about Flat Panel Televisions
Cable Box to LCD monitor - No Picture
I figured I could plug my DCT 6200 right into my new VA1912wb LCD Widescreen Monitor since they are both DVI-D, but no matter what resolution the box outputs I either get no signal or an "out of range" error from my monitor. I can get the picture to flash on for a second but it never stays. My video card on my comp sucks but Im afraid it holds the answer, can I not go directly to the monitor?
SOURCE: LG t.v is saying no signal on the screen for the cable box and a dvd player.
if the sky box is not registered with your viewing card, it will not show. if you want to check that the monitor is working plug in a dvd to make sure its not the monitor that is at fault.
Posted on Oct 17, 2007
SOURCE: Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Posted on May 05, 2008
SOURCE: Insignia LCD TV won't recognize computer input...
i lowered my resolution and now it works perfect
Posted on Aug 11, 2008
  • 40 Answers
SOURCE: Gateway fpd2485w lcd shows video then cuts off
I'm pretty sure the inverter board is bad. you have to replace it if you can or you can let someone else do it. you should find some on ebay for about $80 (not too bad compared to the cost of the monitor: over $200). but its up to you. But first, you should find out if you are still under warranty. good luck. please rate!!
Posted on Dec 16, 2008
SOURCE: E01 Error on pioneer plasma
I've got an E01 error on my Plasma TV . It's a Pioneer. There 's anyone who can help me? Tks ALX
Posted on Oct 15, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
0 characters
1 Points
Got a 19" LG LCD
To convert a LCD Monitor into a TV
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Flat Panel Televisions
No picture. Monitor blinks 4 reds. Tv would come on for a few seconds then turn off. Now nothing but blinking lights. what do I do. Thanks
You have may be broke the system cable, the dvi-d cable is broke...
In my pdp-5030hd have the same problem, probe changing the only the dvi cable and works perfect...
The monitor blinks 3 red and the 4 blinks still in red...
Now i will try to put in the dvi-d input another source like a pc...
You need always the Pdp03u box for control...
Sep 12, 2010 | Pioneer PureVision PDP-5030HD 50 in....
How do I connect my hdtv cable box to the tv/monitor. There is no hdmi input on the tv.
Your setup has a TV/Monitor and a audio/video box. The A/V box is connected to the TV and other source inputs connect to the A/V box. Hookup your cable box to the A/V box either using component video (green, blue, red) RCA cables from cable box outputs to the A/V box inputs OR the A/V box also has a DVI/HDMI input jack which may work using a HDMI cable.
Select the proper source.
Aug 26, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
May 28, 2010 | LG W2361V-PF 23 in. Widescreen LCD Monitor
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Howto connect a ficture/film from computer to tv
there is a wireless signal sender that you can connet to the tv from your computer and it will send the signal so you can use your home tv as a computer monitor from any room in the house. search the internet
Sep 09, 2009 | Flat Panel Televisions
Problem with picture
Most likely it's the LCD panel assembly failure. Either the inverter board or scaler board.
Jan 18, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
No AVC media box
You should be able to use this with only the DVI connection as just a large monitor. You can use a DVI to HDMI adapter as I do believe the display is HDCP compliant. Many AV receivers will upscale to the necessary 1920x1080p resolution that the display needs.
Oct 29, 2007 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Flat Panel Televisions Logo
298 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
