Question about Lexmark Optra S 2450 Laser Printer
Printer cartridge missing
I wonder if you can help
I have had my printer about a year and all of a sudden when i try to change the cartridge i get the message cartridge is missing even though I have removed the foil and put a new cartridge in? can you help, I have changed the cartridge before and never had a problem.
thanks
  • Anonymous Dec 15, 2007
    I get a message: print cartridge missing. When I click on
    continue the letters are half printed
  • Anonymous Dec 30, 2008
    i have lexmark 2400 series and i changed the ink and now it won't print Help!!!!!!!!
  • 56 Answers
Hi does the message read insert print cartridge or close door? Are the any numeric messages on the control panel?
Posted on Dec 04, 2007
SOURCE:
Keeps saying my colour cartridge is missing
Problem
Wrong cartridge; Left cartridge incorrect; Right cartridge incorrect; Left cartridge missing; Right cartridge missing; Error 1205; Error 1206; Cartridge error; Cartridge incorrect; Cartridge missing
Environment
Microsoft Windows XP; Microsoft Windows XP Professional x64 Edition; Microsoft Windows 2000; Microsoft Windows Vista
Solution
Explanation
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
    • The wrong cartridge is installed, or
    • The cartridge is not installed properly, or
    • The cartridge is missing.
What to do
X4850
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
Feb 12, 2018 | Lexmark X5270 All-In-One InkJet Printer
Print cartridge(s) missing or not detected
If you are getting Incompatible ink cartridge error and These cartridges were replaced a year ago, I think its time you call them once again. ( 1-800-474-6836 ) and report the issue. They will ask you for the Cartridge details like part # and expiry date on the cartridge.
Regards,
Sean
Dec 24, 2012 | HP PhotoSmart C4385 All-in-One Printer
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
hi,
the yellow cartridge is '' Y" and not K , you have a problem with the black carteidge "K" replace the black and tell me what is the new message, i will help you. i'm online
Nov 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
Color ink cartridge
Well due to some problem in cartridge you would be facing this problem.however you can do try this.
Please clean your cartridge once again with some spirit.
Fix it well in the printer afterward.
Than use normal paper and print in color.
If than also it does not work that means the bar-code of the cartridge has problem in it so the printer is unable to read that code, so for that you need to change the whole cartridge.
Or if your printer had valid in warranty period and it still in that period just give it to a service center.
If you still had any confusion regarding the same problem or nay other please do reply.
Naiven.
May 31, 2010 | Lexmark X4270 All-In-One InkJet Printer
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
Jan 02, 2010 | Office Equipment & Supplies
I am getting an error message that says "toner is not set, insert toner." I purchased a brand new cartridge, have taken it out a bunch of times and tried resetting it, nothing works. I've had the printer...
I had a similar problem on a Lexmark T520. Some of the off brand generic (and even a few brand name) toner cartridges have slight changes in design that make them miss, or nearly miss the sensor that indicates they're installed. this is usually a metal or plastic actuator on the top of the front panel door.
You can try putting pressure on the printer at different points on the cover. If this wakes up the printer you can either tape paper on the cartridge to make it the right shape to hit the sensor, or get a cartridge from a different manufacturer.
Nov 13, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Print cartridge missing. Install a print cartridge
You need to set the printer look online in google for epson printer reset formats
Feb 28, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a hp 7580 printer. Recently changed ink cartridges, almost immediately afterwards, i received an error code stating the printhead needed replacing. I changed the printhead as directed, rebooted to...
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer suddenly stopped printing
verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
or
1. delete the installed driver
2. turn off the printer and let your computer detect the printer.... let it finish
3. restart your computer
Nov 09, 2008 | HP LaserJet 1020 Printer
Color suddenly won't print
Big nozzle clean up session. Run the correction software. Remove the cartridge[s] and assuming they are full[ish] stand it/them nozzle down on a damp tissue. If this model is head in cartridge, make sure the contact film is clean and undamaged Reinsert try some more Also look at www.fixyourownprinter.com
May 11, 2007 | Canon S200X Ink-Jet InkJet Printer
Lexmark Optra S 2450 Laser Printer Logo
278 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
