Question about HP DeskJet 5650 InkJet Printer
Printing size and shifting to the right
What I see on my screen is fine, but when I go to print on my HP Laser Jet
5650 series, the data is printing larger than 12 and it is printing from the middle of the paper to the right margin, instead of from left margin to right.
I have printing set for Times Roman with 12. , but it does not come out as Times Roman.
  • 417 Answers
Hi there check the print margins within MS Word goto
  1. File
  2. Page Setup
  3. Margins
And check that they are OK. if not check that you haven't got the wrong size paper set in word. Same as above but select Paper size then check in the printer driver that you have the correct paper size selected and that you haven't selected a strange margin.
Hope this works
Thanks J
Posted on Jan 14, 2008
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
Can't print screen in netbook
Print Screen
Use this method to print screen.
Press and hold down the Alt key and the press the PrtSc key, this places the screen image into the Clipboard. .
Open a blank Word document and then Click on Edit - Paste.
The image is then places onto this page, you can up the image by holding down the Shift key and then place the cursor on the bottom corner of the image, then press the left mouse button and drag it down to the right, release the mouse button when you have d the image to your requirements.
NOTE - Holding down the Shift button will maintain the image in the correct proportion.
You can now print this image document and or add text before printing.
Sep 22, 2012 | HP Mini 110-1037NR Netbook
We want to purches a laser printer for printinhg legal size paper,which printer we use
Hello
You can any of HP laser Jet with your budget for legal size printing, all printer can print legal size printing, however there are some printers for quick reference.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
Dec 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Oct 04, 2010 | Xerox WorkCentre 7328 Multifunction laser...
When print a file, the printer screen show ''Data Received'', So I can not print anything
the printer is missing something. Check if there is paper. also check to make sure you printed the right size paper. If you printed 8.5 x 11 sheet make sure that paper is in your tray or if you printed a different size make sure that paper is there. Than if all is good just restart your compouter and printer and it should be fine.
Jul 16, 2010 | HP LaserJet 5200 Printer
How to print borderless 5 x 7 pictures using an HP psc 1310 series printer I'm using 5.0" x 7.0" hp premium glossy photo paper and a hp psc 1310 series printer and i cannot align the paper properly to...
Open printers window, right click on the psc printer icon , select printing preferences, click on paper\quality tab, select the paper size as 5x7, check the option as borderless printing and click on apply and then oK...
Try to print ,,,
Dec 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
Printing mailing list
Sounds to me like the word doc's page size is not set to the same as your printers tray.
In word, file , page set up. page size/paper size is set to "letter" in US I think is standard, it's A4 in Oz
On printer driver check page size setting too
Contral panel, printers and faxs, RIgHT click on brother printer icon, properties, printing preferences, page size
post back
Nov 17, 2007 | Brother HL-2040 Laser Printer
Margins not recognised
Hi lerona - I have a 5600C series HP printer. You might try these tips:
Do a Print Preview to be sure the document looks right on your screen, then in Print Setup, down in the Zoom box check the Scale to Paper Size to be sure it isn't set for the wrong paper size. There's an arrow to scroll to the size you're printing on.
Then click Properties, then the Paper Quality tab. There's an item that says "minimize margins". You could try printing with the box checked (if it's not now), or unchecked (if it IS now) and see the difference. Click the Effects tab and be sure the "normal size" box says 100%, and that there's no check mark in the "borderless printing" box.
I print documents all the time, as well as photos, smaller sized items, cards, etc., and have had no trouble with the margins printing differently than my Print Preview shows on my screen. I hope these tips help you. Good luck, and feel free to email me if you have any success with my suggestions.
Jo
JokerGirl524@aol.com
Oct 28, 2007 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
268 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
