Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
My Whirlpool DU1055XTPS makes a horrible contiuous buzzing noise through most of the wash cycle. Although it does change in pitch and frequency during drain, wash and fill, it never really goes away. It sounds like it is coming either from the control panel or the left side, but I cannot be sure. It does not sound like an obstruction in the pump or motor, but rather more like an electrical resistance sound. It does not sound like a warning buzzer, but maybe it could be one that is vibratign at an unusual frequency. There are no error lights, and the washer goes through all of its cycles appropriately, but the noise is defening. Please tell me what to look for or how to diagnose this problem.
Thank you,
Charles
  • 126 Answers
First thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
Posted on Dec 12, 2007
2 Suggested Answers
SOURCE:
  • 4102 Answers
SOURCE: loud continuous buzzing noise while dishwasher is running
Hi hope you are well have you checked that the dishwasher isnt touching your units either side their should be a slight gap either side you will get this noise if it is touching anything at the sides or pressed up against something at the back if this is not the problem.
If it is making the noise through most of the wash cycle the the chances are it isnt going to be a pump on the way out the only other thing it could be is the motor that turns the spray arms around and it could be either the top or bottom usually if you can get to the motors you can oil the moving parts as sometimes thse get dry over time.
Try the first sollution first try moving the dishwasher a bit and then try it again if still noisy then the chances are one of the motors has got noisy on the spray arms it wouldnt be the pumps as the noise continues through most of the wash.
Some times just moving the dishwasher will recitfy the problem as the same happens with fridges and freezers if it has been knocked and is not level or is touching a unit you will get a slight vibrating noise so try moving it a bit.
Let us know how you get on
Posted on Nov 28, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud continuous buzzing noise while dishwasher is running
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 14, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
Hi!
The noise is coming from the power board may be a loose connection or a cold solder joint
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Extremely noisy Whilrpool, sounds like electrical resistance.
Mine did that when the end of the impeller broke off- the sound is the grinding of the remaining end of the impeller against the gears on the engaging end of the chopper. You'll need to get out your screwdriver to dig in deeper and find out if this is the problem.
Bad noise at begining of rinse cycle.
It sounds like your gear case (transmission) has gone bad. If the washer fills and agitates that tells me that the problem cannot be with the motor coupling and drive motor. It also rules out a pump problem if the washer completes a wash cycle and drains properly. The only thing left is the gears inside the transmission. Sometimes they go bad in a way that portions of the wash will work while others don't. The part number is 3360629 and the price usually runs about $150. I hope this may help you in some way.
Sep 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
869 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
