Question about Brother MFC 210C All-In-One InkJet Printer
My printer won't print.
I replaced the black ink cartridge and the printer sends a cleaning message. When I push the copy and black start button, the paper goes in, the head goes back and forth, but the paper comes out blank.
I also keep getting a message that my printer is not connected to the PC. It was working fine until I replaced the ink.
    Problem Solver:
  • 16 Answers
1:check the usb cable or replace it
2: remove the black print cartridge clean the contacts then reinstall it
Posted on Nov 28, 2007
  • 832 Answers
Make sure that the carts are well placed and secured.
press menue then start mono (blue copy button) then fourtimes arrow-up (tel index). machine will be in maintenance mode and all lamps will flash. press 7 then 6 then 4 then start mono (blue). machine will initialize the carts: refill tubes and printhead with fresh ink and do some cleaning cycles. after showing maintenance in the the display leave it by pressing 9 then 9. do run a quality test print by pressing ink etc.
If you cant see anything the printhead has crashed and cant be fixed anymore.
BTW: Check the usb cable connection and restart the pc.
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Why won't my Lexmark 5600- 6600 Series Printer print in color?
It could be the print setting on the application where you're printing from. Before you send your print job and hit "Print" button on your computer, check in the Printing Preferences and make sure it is not set to print "Using black ink only.".
Mar 06, 2012 | Lexmark Office Equipment & Supplies
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
2. Open the scanner.
3. Open the cartridge cover.
4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
7. Remove the yellow tape from the bottom of the cartridge.
CAUTION:
Do not remove any other labels or seals, or ink will leak.
8. Insert the new cartridge into the holder and push it down until it clicks into place.
9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
10. Close the scanner.
11. Press OK to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
