Question about Olympus Stylus 700 / 700 Digital Camera
Missing Pictures I transferred my pictures from the memory card to my laptop and when I put the card back in my camera it was blank, please help.
  • 4 Answers
You may have chosen the delete from camera option. When you transfered the photos.
Have a closer look at the options when you download the next lot of photos, some times there is a tick box for delete while transfering.
Posted on Apr 17, 2008
SOURCE:
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
Can't veiw pictures from memory card on camera
Some cameras do not allow a computer to camera transfer. It causes the card to have a different initialization not compatible with your camera. If the pictures are safely on your computer, format the card in the camera and it will be fine.
Nov 14, 2009 | Samsung S760 Digital Camera
I copied pix to laptop using Nikon Transfer. I
Try formatting the memory card in the FujiPix 2800 camera. See if that helps..
Oct 01, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Can't find pictures on SC card
Try transferring the pictures to your computer then erasing the copies on the sd card, then putting the pics back on the sd card from the computer and then of course back to the camera.
Mar 16, 2009 | Panasonic DMC-TZ5 Digital Camera
Product: Sony Cybershot; pictures will not download from camera
It is possible that USB post in camera got broken/ defective.
Easiest way is to take out memory stick from camera and put in to memory card reader and transfer pictures in laptop or PC.
Feb 23, 2009 | Sony Cyber-Shot DSC-P93 Digital Camera
What to do, I forgot to put memory card in HP R707?
Hi
Do you want the pictures transferred to your memory card? that depends on the option available on the camera, try inserting the memory card. select a picture then check options if you can move it to a memory card. if not, download it to a computer and transfer it to the memory card folder.
Hope this help
Jan 11, 2009 | HP Photosmart R707 Digital Camera
How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
Oct 05, 2008 | Nikon Coolpix 2000 Digital Camera
I have a Kodak Easyshare C530 how do I transfer pictures from computer to camera?
hey, yes you can transfer pictures from the computer to your camera...you take the memory card from your camera and insert it in your computer (if you do not have the slot to insert the memory card you cannot transfer pictures) thn sync pictures to the memory card and then insert memory card back into camera.
Jul 19, 2008 | Kodak EasyShare C315 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Olympus Stylus 700 / 700 Digital Camera Logo
54 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
